my old R33 GTS-T had misfiring issues from day one... could not even cope with 180rwkw... Splitfires were the fix for it...
my current car R33 GTR is now putting out 270kw at the wheels with the standard coilpacks... no spark issues at all
"if it aint broke, dont fix it"
There is a shortage of hard evidence on coilpacks.
The stockers have the track record.
Splitfires are getting a track record over a few years now.
I have bought a set of Yellowjackets on the basis of bench tests i have seen but they still have to prove the lasting qualities.
The red ones appear to be lesser quality but again time will tell.
I had a similar issue ~ 18psi (250rwkw mark) and the new coil packs resolved the problem.
Running 18psi initially was ok on the original coil packs, replaced spark plugs, tried the silicone coating which helped slightly but the misfire came back.
Ended up buying the yellow jackets and the problem has gone. When I get new spark plugs I'll buy the ones gapped at 1.1mm (against 0.8mm) now and see if the spark still holds.
Last post in here covered it
http://www.skylinesaustralia.com/forums/Gc...20&start=20
Edited by benl1981
Well I dunno what your car setup is, but usually when a person runs an atmo bov on a stock ECU it will run a bit richer on gear change and cause a bit of a pop/backfire through the exhaust.
whats the silicone method? smear house grade silicone around what part of the coil? what are the first signs of missfire on a 25det with only breathing mods that runs std boost?
first signs of a missfire would probably be the missfiring, under max boost between 3-5k rpm, or randomly cutting out and having popping sounds like a wrx until you either turn the engine off or it fixes itself. ive had both.
i was trying to find the coilpack silicon-ing diy but didnt manage it, same principle as these
http://www.skylinesaustralia.com/forums/Fi...=coilpack+clean
http://www.skylinesaustralia.com/forums/Mi...500-t32356.html
Edited by Galois
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
