Tried to find anything on the forum in regards to fitting the front subframe from a R32GTR into a HR31 to convert to AWD once i fit an RB26DETT in it. Anyway know of any other forum questions like this? Does anyone know the dimensions between the chassis rails of the GTR in the engine bay?
https://www.sau.com.au/forums/topic/327442-turning-hr31-into-awd/
I have never heard of this being done, doesn't mean it hasn't been thought about or done before.
Anything is possible, but it will take time and patients. Helps if you can fabricate things yourself.
Not an HR31 but this guy has the full GTR running gear in his S14: Link
Good luck with it and make sure that you create a build thread if you go ahead.
Someone did it to an oldschool RWD celica, basically had to cut and shut half the car to do it though.
No offence but this is a pretty retarded idea, you will spend a ridiculous amount of money to end up with an unregistrable hack of a car that will most likely have completely messed up suspension geometry and handle like ass. Why do you want to do it?
To be honest if you have to ask people on a forum how to go about it, you probably aren't the kind of person to be even attempting it.
the man asked a question on any other places to look to get ideas on the modification i dont see where he asked for ur opinions on the matter.
the only thing i can say is its alot of work but its doable start looking for the people who have done it to the vl's and id say ur somewhat on your way to figuring out whether its viable/in ur price range, or not
but as everyone said BUILD THREAD plz
Of course it is doable - however the time, cost and effort need to be really addressed as there is extensive modification just to get a GTR REAR end into a HR31...
Let alone the front end as the subframe sits lower and so on as my RB26 sits signifigantly lower to the ground than in a GTR.
I'd also question if the transmission tunnel can even allow for the driveshaft as my initial inclination would be a no, meaning floor cutting as well.
A good question here is this:
Will the added weight & customisation of the 4WD really make a HR31 that much faster than if you spend even just half that money on the HR31 IRS and reconfiguring it with weight advantages already posed.
Nismoid you think too much... weight, faster, money! You are jealous because it will be cooler than yours ;)
Just do it. Buy an R32 GTR (complete) take out the running gear and sell the shell to me for real cheap. Then a**hole everything into an empty HR31 shell.
Easy right?
Of course i think too much. I get paid to do so afterall.
After putting together a motor for 5 figures, then all the rest, you really have to "draw a line" at some point on a shell that is essentially worth nothing.
Going 4WD would be "that point" given the price of R32 GTR's these days :)
That's not to say I've not thought about 4WD myself, looked into that as well a few years back :)
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
