What kind of problems would i have with regency if i this http://www.skylinesaustralia.com/forums/R3...56#entry5337356
Performance Features....
- Splitfire coil packs - no problems
- 550cc injectors - out for Regency
- 550 hp ATR-43 turbo - out for Regency
- Z32 Air flow meter - off
- Stealth return flow front mount intercooler - fine as long as no chassis is modified, holes are cut properly and mounting is secure
- Greddy turbo timer - take it out for regency
- Nistune ECU - not sure, but probably remove
- Trust turbo back exhaust - as long as its quiet enough
- Extreme heavy duty street button clutch - fine
- Walbro fuel pump - fine
- Tuned by Dr Drift on a safe tune of 236rwkw at only 15psi, easy to drive (I drive it everyday) and decent fuel economy. Will easily get 450kms to 50 litres with highway driving.
The wheels are 18's, with Kumho ku36's on the rear. - should be ok by the looks.
  • Replies 89
well unless you know how to take the turbo and injectors out, i wouldnt do it yourself. But alot of those mods aren't standout type mods, so you should be fine for an ID inspection.
I'd leave the turbo on if you take it through regency as with the Z32 AFM - Only if you get pulled up on it. I'd leave the nistune ecu, absolutely no way they'll know, even if they pull the ECU apart I put my balls on the line they won't know what they're looking for. Injectors can be a kent to do, turbo timer could take 2 minutes.
The 34 looks stunning mate btw!
Yeah those look pretty bad - though I've seen worse (check out some of the r33s on the road!)
Anyways, you can polish them up with various products - I've tried just about everything from plastx to toothpaste to brasso. I recently used one called 'glassylite': http://www.glassylite.net.au/ which was supposed to have a UV sealant and stop the clouding happening again. Guess we'll see if it works!
Got other pics of the car?
Another prospect car.
car 6 link
My only concerns are:
1. its nearly due to 100k service
2. selling it on behalf of his friend who is over seas
3. not sure exactly what to look for when inspecting it (anyone come along with me help me check it out)
i've seen this car parked on the side of the road in Modbury with the for sale signs up in the window. It looked VERY clean on the outside
The guy i rang "Jeff" was selling it on behalf of his friend who was over seas, i dont know how that would work (signing it over) without him being there :S
But im sick of seeing silver skylines, gotta go black or red :P
Edited by Blazk
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
