  • Replies 129
chasers tune on a knife edge sometimes.... racepace tune could have been safer
I actually thought opposite, my car was tuned stupidly safe.. Made the power but it was just stupidly laggy, they gave me a pretty dyno sheet to say i made power but it was all uptop and useless downlow.
My favorities from driving peoples cars, and graphs and talking to people..
Status Tuning - Dr.Drift
well as i said before i went with status tuning and couldnt be happier with the service and the tune !! my car feels so much smoother but gets up to speed alot quicker its great.
i went from 171rwkw to 188rwkw which will make me happy untill iv dont my suspention and breaks then my target is atleast 235rwkw,
anyway here is the dyno sheets.
oh yeah its a series 2 r34 gtt with
blitz FMIC
jjr belmouth dump pipe
cusco 3" high flow cat
drift pod filter (makes no diff)
running 12.1 psi boost
thanks again trent the car felt great on my way home !!.
woh... you had some wavy ass curve going on there initially ey? :banana:
Nistune? is this the first time tuned or has it been tuned before?
no first time nistune ! on the first run trent said that dip is were i would feel the change the most .
right oh, looks fantastic now, you'll definitely notice it that's for sure.
do you have an aftermarket catback exhaust?
yeah its a 3" jasma (very quiet ) trent said if i get rid of the center mufler i would get more power but for what it would cost it wont be worth it !!, also he said iv im chasing more power down the track its better to have the quiter exhaust so i dont get hastled by the cops .
blitz FMIC
Good work,
Hopefully i can nistune my car soon =D
Any other differences apart from a smoother drive? I.e. Do you feel a big power difference mid-top range?
Cheers!
Heres my tune from Trent, this is my 2nd tune from trent with a new turbo, been thrashing my car for 2 years now with trents 1st tune and and this 2nd tune and still going strong!
Uploaded with ImageShack.us
On the stock ecu you made 171rwkw and made a 18rwkw increase from nistune?
I'm not very well informed about skylines as I own a s15 but that power figure is impressive for a stock ecu.
I have pretty much the same mods on my s15 and make something along the lines of 145rwkw :starwars:
Oh and will be heading to Status/Chequered Tuning when they have free spots!
I have pretty much the same mods on my s15 and make something along the lines of 145rwkw :P
Yeah it had a boost increase already to 11 psi so the base peak was good to start with but look at 3000 and 5000 rpm.
3000rpm gained 20rwkw and 30nm
5000rpm gained 45rwkw and 70nm
that's where the differences really show.
Good work,
Cheers!
hell yeah since trent did his work she just keeps pulling strong its a great feeling
before the tune if i wound out 4th gear it would run out of legs but that just isnt there anymore its a totaly different car i love it
thanks again trent
thanks again trent
Lol winding out 4th only on a private road of course :P
oh wow a nice torque and power gain!
I'm very impressed with the tune and skylines in general :P
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
