  • Replies 165
Shane with your sound system you'll last like what, 2 minutes before your battery is flat? :D
Haha true. but i have some wicked head phones into my radio on my phone which will keep me entertained... i guess my passenger will miss out! LOL. oh, and i guess i'll be cold also, oh well. lock me in i'm there!
quick question whats the place like? as in can a lowered car get in/out easily? don't want to leave my carbon fiber undertray behind on a bump.
There's not any steep inclines or anything.
The bays to park on are on a little hump so your car can sit at a comfortable angle upwards for you to see the screen easier rather than having to look up.
My car had no problems there but I have stock suspension with Nismo kit.. but I'm pretty sure if I was lowered as well, I would be fine there still.
I'll see if I can make this. Need to fix the speakers in my car though, the passenger door speaker is cutting in and out constantly and I have no rear speakers after they put the baby seat anchors there so I effectively have one working speaker haha.
Hey guys,
getting down to the last few days before I need to inform village of roughly how many people are coming (19th).
If anyone else thinks they may come please let me know earlier rather then later.
Thanks
any eastsiiide pre meet?
any west siiiide pre meet?
anyone able to pic up sam enroute? cause i have to come from pakenham and dont think ill make it in time if i have to head that way too.
danni, we are meeting at the apple peal, check the first page :(
ah oh dear i cant find that place...ever LOL
Oh and adam (sorry for getting that wrong huni) you win :)
for now :)
