LOL!
Oh yeh, dont think anyone else will, but you can bring your dog with you in the car.... my little buds coming with us as normal.
lol my dog will got nuts if i bring him
So is the grounds at the drive ins all gravel / dirt area is it?
im pretty sure from what i remember the coburg drive ins is gravel and entrance driveway is steep...but dont quote me on it, its just from what i remember
  • Replies 165
The coburg setup is this:
concrete driveway into the place with 2-3 speed humps, they are the low crappy ones, go slow
then from what Jess and I remember, they have concrete driveways to the cinema areas.
When you get to the cinema area there is a layer of gravel over the lumpy concrete which you use to angle your car at the screen.
Yeah confirm me :D
ok, added
I think you missed this one.
Thanks for that.
Updated:
Attending
WYTSKY
scarface_au
cowboy1600
Shanu
cha_chaos
MUZTEK
JPCR33
vspecIINur
33gtst
IMSLY
OOSKYLINEOO
Basti
Jezza-gtR
PRIMRK
KerrKnight
perzn_34
AussieR31
Birds
Vspect
+1 other
Maybes
sarah_loopz
paulr33
GTR-Boy
unco
MrWindSurf
ok so I know im a massive delayer. still put me down as a maybe cause the bro said he wanted to see this movie, but im not sure about the bf lol
as for entrance etc.. it is a concrete driveway but be careful of speed humps.. they are the shitty kick strip things and if your car is lowered be very careful.. as for the drive ins, they are gravel, so be careful of cars behind you because i doubt anyone will be too happy with a million and one stone chips lmaoo
hope that helps
hey mate...is it too late to put one more car (ma mates) in the list?...
thats ok.
ok no worries.
I spoke to the village guy today and as long as we have the minimum 20 cars we are good, a few more is absolutely fine. so everybody who said they are attending please do! :nyaanyaa:
:nyaanyaa:
Well this morning I went to put the car in reverse and it won't go in, the clutch fluid deiced to leak out.
The Flexible Hydraulic Hose that goes to the Slave Cylinder needs to be changed.
I felt a slight "spongy" feeling with my clutch pedal, but still had a 'friction point' last night and not till this morning it all went.
I can still use the car, but I have to top up the clutch fluid and keep a spare full bottle of fluid in the car.
But I want to get it fixed and don't want to drive it around leaking clutch fluid.
If it is repaired by Friday, I can come down, if not I give it a miss...
That sucks Jamie!!! Where do you live? I know it's local but I'm not sure specifically. Since you need to borrow someone elses speakers anyway we might be able to arrange a pick up if you're keen :)
Sure Charlie!
I can msg you when the time gets closer...
See how I go, thanks :)
If anyone wants to come but doesn't have a car or happens to own a failing GTR, I has a front passenger seat that you are welcome to (pending my sister's reply) :O
Also have a nice little sound system that I can't wait to test out on a drive-in :)
that sucks man :O
please do come with someone else. be good to catch up.
Yeah, I'd probably give Charlie a call as she offered.
oh nooooo! not the R.... :)
Hope you can get it fixed in time.
Well my mechanic is getting a hose, I guess I can top up the clutch fluid and drive it and keep a spare bottle and putt around.
If anyone wants to come but doesn't have a car or happens to own a failing GTR, I has a front passenger seat that you are welcome to (pending my sister's reply) :D
Also have a nice little sound system that I can't wait to test out on a drive-in ;)
LOL!
Thanks Birds, I'll give Charlie a buzz 1st and see how I go and I should be alright with her.
The job to get it fix should not be too big.
Attending
WYTSKY
scarface_au
cowboy1600
Shanu
cha_chaos + OOSKYLINEOO
MUZTEK
JPCR33
vspecIINur
33gtst
IMSLY
Basti
Jezza-gtR
PRIMRK
KerrKnight
AussieR31
Birds
Vspect
+1 other
Maybes
sarah_loopz
paulr33
GTR-Boy
unco
MrWindSurf
Also, jut did a quick run from the car wash to bell st to make sure I knew the right way.
Here is the final route. I will bring some print outs too.
!!!!!!! i just discovered this thread. count me in IF i can find a lift off someone.. :thumbsup:
You're in Wantirna yeah? If so I can get you man, it's not looking like I'll have a passenger.
EDIT: Man, if I hear Inception being advertised once more on the radio I'm going to f***ing scream. It's ruining the movie for me. And /b/ already ruined the movie for me.
Oh ya...the radio...hope the frequency in the japanese radio range...didnt even think about that...if not ill have to hear the
movie in someone elses car...lol...
Don't worry I too have jap speakers and apparently its in the range
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
