  • Replies 49
Posted Images
Price drop $7000 ono for engine or offers for head/bottom end/inlet gear
$700 for injectors delivered
$400 for engine loom delivered
Power FC D-Jetro sold
Ported RB26 head with 1inch oil drain $2200 ono
RB30 block and crank, Precision Rods, ARP rod bolts, ACL race bearings, ARIAS pistons, Tomei oil pump, Jun crank collar, 1mm head oil restriction, twin tensioner belt setup and Modified larger sump $5100 ono
GTR inlet gear (plenum, throttle bodies, injector manifold, attachments) $1200
6x SARD 800cc top feed injectors $700
Garrett T04z $1100 ono
Engine loom (modified, use to link R32 gts-t to a GTR aftermarket ecu) $350
Edited by =premo=
I was wondering if the Tomei Oil Pump will fit the RB26 and If your willing to trade the rear housing .84 for 1.00AR with some cash? let me know thanks
Would like to sell turbo as is because its a very good setup for medium to high power RB25's and bigger.
Tomei pump will fit all RB engines (RB30 requires a lug to be ground back on some blocks but its easy to do with a grinder)
Turbo beanie wasn't in very good condition so I sold it with the Turbo kit but I do have another stainless heat shield I could sell for $50 But it requires two bolting points to be made and welded to the turbo dump.
Sorry I took the pics but forgot to upload them.
Shield will go free with turbo or listed with turbo on ebay if they haven't sold soon
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
