hey guys just last night i was at a friends place who lives up north and as i left i realised someone had tried to break into my car ~_~;; the entire section behind the driver side window was pretty much ripped out and had marks all over it from repeatly jamming something into it. Recently i have seen on these forums toooo many people having their cars stolen/torched i guess i am a lucky one since i still have my car with minor dmg. anyone have any good solutions that can reduce this bs.... i mean stuff steering locks? other things that may help? or possible a good alarm system?
thanks
https://www.sau.com.au/forums/topic/328037-car-theft/
I know I sound like a broken record, but anyone who owns a Skyline and doesn't have an alarm deserves to have it stolen and just causes all our premiums to be sky-high.
MINIMUM should be a decent pager alarm (so you get notification from up to 1km if anyone even goes near your car), with 3/4 immobilisation points, a kill switch (I have 2), AND a Club Lock. I believe the Club Lock is the MOST important, as more often than not thieves will see it and think "too hard" and move on to the next car.
https://www.sau.com.au/forums/topic/328037-car-theft/#findComment-5334847
You mean to say that you never considered an alarm before to deter theives?
Keep a f**king big dog in the front seat
I can also be employed to sit in the front seat, with my masculine frame and bulging biceps, i assure you theives wont be a problem.
https://www.sau.com.au/forums/topic/328037-car-theft/#findComment-5334878
+1 to alarm
2 or 3 point alarm - you are mad if you have any sports car without one, and your insurance might drop for it as well.
Plus get a huge snake to sit on the parcel shelf, it will keep it warm and it can eat rogue flies...
https://www.sau.com.au/forums/topic/328037-car-theft/#findComment-5335012
the other day my alarm went off the car is in a lock up carport with a door too the house i went screaming out only to find my dog was locked in the carport somehow and his barking had set the alarm off didnt think it was quite that sensitive . but he as a loud bark and i guess it echoed in the carport .
mind you if it had been a thief and the dog was there i would pity them our german shepard has a thing about people he doesn't know :-)
https://www.sau.com.au/forums/topic/328037-car-theft/#findComment-5335230
Like this?
https://www.sau.com.au/forums/topic/328037-car-theft/#findComment-5335280
Im with Crawler, If you drive a skyline a good alarm is a must. Black wire, battery backup, 3pt immobilisation, shock sensors NOT JUST glass break, pager... ect ect...
and if you MUST have a timer get it built into ur alarm module don't have a standard pen gredyy or apexi one. Its giving the theives everything they need in coloured wires nice and easy to get to.
https://www.sau.com.au/forums/topic/328037-car-theft/#findComment-5335493
thanks
Sounds exactly like what happened to my old 32 in the Northern suburbs (TTG/Mobury area)
Except they caused nearly 5k damage trying to get in.
a good alarm would of gone off with them tampering with your car
used in conjunction with a brightly coloured club lock in your hand to beat them with it
I like your thinking Steve!
https://www.sau.com.au/forums/topic/328037-car-theft/#findComment-5335635
