Hey,
first off I don't want to hear the flaming. I am on good driving behaviour atm and get my full opens back on 12th August. On Monday the 5th of this month I got done for 33km over and that is 6 points.
I work 48km from home and there is no public transport in mackay so I have no way but to drive to work.
Has anyone ever asked the court if they can get have their lisence back and plea remorse?
Thanks
https://www.sau.com.au/forums/topic/328059-anyone-have-some-advice-on-lisence/
I dont like your chances dude, unfortunately they will just use the "shouldda thought of that before you drove like that" excuse. Take lube to court. Lots of lube. Double your orignal punishmet and that's when you'll get your license back, then add the fine for the 33km/h over...
Good luck dude.
P.S. Been in this situaion before with a 3 month suspension, there's no way around it.
+1 for taking the lube to court. you're probably going to get fisted by the long arm of the law.
if you get a nice judge you may possibly scrape out of it with a work licence (allowing you to only driving between certain hours), but i find it highly unlikely.
my suggestion, look for accomodation close to work
Hey,
Thanks
Apply for a SHO (Special Hardship Order). You will have write an affadavit and get one from your boss explaining your situation and why losing your license would cause a hardship.
It is considered hardship if losing your license means you are unable to keep your job etc. I got one when I got done on my good behaviour period because I had to drive 1.5 hours to work and an hour to uni on some days. No public transport out where I was living at the time.
You won't be able to drive any other time other than that specified on your SHO and you need to keep it in the car at all times.
Good Luck.
Good Luck.
thankyou. Did it last just for the suspension time? How did you apply for that?
6 months for a SHO call up QLD transport and ask them about it or go in to ur local transport/government place and get the forms and talk to them about it. You will have to go to court to get it all approved etc.
Might be stupid question, but how does anyone tell that you are driving on one of these SHOs? And how can they know if you are driving within the conditions of the SHO so they know whether or not to pull you over to check?
Too many people keep getting caught and being charged with "driving while disqualified". SHO seems to half defeat the purpose of being punished for breaking the law.
Solution would be to find someone willing to play chauffeur for the period of your disqualification. Or move closer to public transport.
probably shows up in the police database when they run a rego check on the car. my grandparents got pulled over because the car was registered in my grandfathers name and he no longer has a valid licence (handed his licence in a few years ago due to developing a condition that eventually sends you blind). the police pulled them over to do a licence check and they explained it. funny story though, just as the police officer starts to walk back to the car my grandfather says in a loud voice to my grandmother "good thing they didn't get you blow in the bag". the officer did a quick turn and walked back to the window.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
