Greetings, SAU. After lurking for way to long, I have decided to make my first topic, asking questions and just being a general nuisance. My car, a 5mt 92 gtst, seems to be.... Rev happy?
After a recent cruise with a bunch of other skylines, I finally got around to getting an accurate calculation of speed vs rpm on the highway. I was kind of surprised:
5th gear, 4000rpm = 123km/h GPS verified. As far as I know, I have the stock 4.3 diff. However, I also have noisy gears, 1st, 2nd, 3rd, and 5th all have a "straight cut" gear sound. It's not dogbox levels of whine, but it's definitely audible in the first few gears (less so above 3rd gear, as my exhaust is way too loud). From what I've gathered, my highway RPM's seem much higher than everyone else that I know who also drives an r32 gtst around my parts. Did Nissan really gear these cars so aggressively, or do I have aftermarket gearing? As it stands, if I'm booting it and I shift from fourth into fifth, the way it pulls in 5th makes it seem like there really should be a 6th gear, like 5th is purely an acceleration gear, rather than an overdrive.
I don't really mind cruising along at 4000rpm, don't need to downshift to pass. But it absolutely rapes my highway fuel economy! As a result, I tend to do the speed limit on the highway, since it's never any higher than 100km/h until you get out of the city (the city being Vancouver, if anyone's interested).
Thanks for your time ;P
4000rpm @ 123kmph? what is it at 100kmph?
and what size tyre
sorry about taking so long to reply :X Car was down and out for a bit while I was doing some stuff to it so I couldn't test on highway. Speed in 5th gear at 3000rpm is 95 km/h indicated, 94km/h on GPS.
Tire sizes are stock HCR32 front and rear, 205/55/16. Pressures are 36psi front and rear, although I don't think that would have an effect at all... is my speed/rpm in 5th gear normal?
The answer is yes it appears normal 4.3:1 is quite short - would drive me bananas but some people who are more interested in dragging from the lights seems to like it. My Stagea has a 4.1 final drive which I find too short. I am looking to change it for a 3.545:1 off a R34GTR which should be fine when my RB30 is fitted.
4.1 V's 4.3 makes very little difference, about 2950 at 100 for the 4.1 and an Rb20 certainly feels more lively with the 4.3 ratio.
But the O.P.'s numbers don't add up.
Your first post said 4000 = 123kph, via GPS.
Something is wrong, it's just maths.
3000 at 100kph equates to 4000 at 133kph.
I'm going to be on the highway tonight, so I'll come back with hopefully more accurate #'s. Perhaps my tach is a bit out as someone mentioned. Since it doesn't sound out of the ordinary, I can't really complain. It certainly is lively in the first three gears :P
Thanks for the replies everyone :)
Yeah, seems to have very short gears. I find them short even for an NA, would feel even shorter in a FI i would imagine. Mine also sits at roughly 2950RPM at 100km/h (GPS reading). Feels like 4th gear sometimes.
Edited by TyresBro
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
