hey all, ive owned this car for about 3 weeks, and it has a set of volk racing wheels, unsure on the exact brand, anyway, i cant get a socket or wheel brace to the nuts, the wheel nut holes are to small, where can i get a small socket to fit the nuts?
ta
https://www.sau.com.au/forums/topic/328853-cant-get-socket-on-wheel-nuts/
maybe buy some internal hex wheel nuts?
thats what i had to do with my '32. the nuts are M12x1.25.
i paid $40 for 20 of them and they came with a hex bit as well.
other than that Stahlwille make some very thin walled sockets but they are massivley expensive. try about $750 for a basic socket set.
you may need to get a good quality socket as the cheaper ones are too thick to go in. then as said above, get some of the allen key head nuts.
or you can do what old mate in the honda did and take to the wheels with a saw............ LOL
as for getting the old ones out, best bet would be to drive to a hardware shop, or a decent tool shop and explain to them your problem and see if they will let you try some sockets to see if they fit. generally your better sockets such as stanely, kingchrome, snap-on etc will make skinnier sockets because they are made from stronger steel so don't need to be super thick to make up for being weak.
some tool shops have those annodised slimline sets in 4 colours that have the plastic covers on them to stop the socket from damaging the wheels. these are normally long and skinny for this purpose.
DO NOT USE INTERNAL HEX WHEEL NUTS!!! Had these on a rally car I bought and after heating cooling and a few wheel changes (fair enough rally car gets wheels on and off a lot more than a road car..) the pressure out on the inside of the nuts cracks them. If you simply think about the pressure is being applied as you tighten and loosen you will soon see how easy this can happen.... It may be poor quality, it may be a lot of work and all the hot cold, but I will still never use them again
you more than likely have 13/16th or 21mm nut's, best bet is uselly to use a spark plug socket, these are thin in the wall
and will get you out of trouble.
Nissan use 21mm wheel nut's, head down to your local tyre shop and buy some 19mm nut's and you should be right
and i aggree DO NOT use those stupid inner hex nut's, the amount of these that i've had to remove is huge..
you have to drill the head of the stud, and it's a massive pain in the arse, and we charge $65 per nut removelly
The Enkei rims I got came with a thinner extension as most sockets cannot get to the nuts due to the wheel design.
I'm sure you can buy them somewhere, or you can take any of the above tips.
LMAO!!! that link is hilarious. i like how the honda boys are blaming it on VW........who cuts a wheel. honestly. and then tries to justify doing it? hilarious read. my life if now better having seen that.
sry was off topic (sorta), all ideas above are good :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
