Hey guys, i have come to a extremely annoying issue with my car. Its a s13 with a std RB20 in it nothing is modified or changed or anything like that as for yet.
The problem i get is every morning before work i start the car it hesitates to start it almost acts like a carby car were i have to pump the throttle fast to get it started then it will splatter for bout 2-5secs then runs perfect, ill have a smoke while motor is running to warm it up then i cruise nicely for about 5mins until i get to the freeway at this time the temp is on half which is normal now my problem is this the car will not rev passed 6-6500rpm it will splatter and the exhaust note changes and has a flat spot as well as power is not there. The only way i have found out to resolve this is to drive the car for about half an hour turn the motor off start it up and then the power is there perfect
Yesterday my mate suggested my Coolant Temp Sensor is faulty, the two pin yellow sensor near the temp sender for the cluster.
Has anyone else had a similar or the same issue or what can i do to get it fixed.
is there a way to temporarily bypass the sender just to make sure that is the fault?
thanks
https://www.sau.com.au/forums/topic/328867-possible-faulty-coolant-temp-sensor/
is the gauge reading accurately? it should take a good 5 - 10 mins to warm up then should sit either just under half way or bang on half way (if its pretty hot) if this is the case then its doing its job properly id be looking else where.
I unplugged it on the way home from work still the same cold startup but there was a slight difference felt little like it had a flat spot at about 2500rpm on the freeway. Yeh temp guage is working to how it should be
of course it will feel flat with the water temp sensor unplugged
the ecu will run basic retard mapping and perform sluggish but should still run
the main focus was did it change or alter the cold start issue?
nope didn't make a difference.
I can put a multimeter across the sensor at cold start until warm up and see what ohms i get out of it. I know that GTRs have the same sensor and i noticed they look the same as a vl but im not sure if it will work. I guess i can just try getting one from pick a part and see how i go?
thanks
oh n Geraus its not knock sensor as my 32 4 door had an issue with the knock sensor and it was a totally different issue
hahaha yeah i have to one day...
um consult port not to sure about that, its all in a s13 i done the conversion is the port just a plug off the loom near the ecu? ive never really looked into it
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
