  • Replies 56
iv always wondered if wheel clamps are sold to the public because it would be a good investment and would do more then a club lock for the steering wheel
I have seen these in a auto shop,can't remember which one though,look around. :blink:
yeah they would be probably one of the best things to do
Best alarm system is putting spike strips all around your car and bolting them into the ground, a steering wheel lock, alarm, immoboliser, and spike strips bolted into the ground at the exit of the carpark. thatll ensure those good for nothing theives dont take ur car.
It's hard to get GTR's in the USA where I am from. When I first heard I might have the opportunity to work in AU I started looking to see if I could get a GTR here.
I was really excited when I found out I could get one. That car is one of the first things I purchased when I arrived.
Still hoping to get some info... I don't want anyone else to go through this..
If I ever caught anyone in the act trying mine, I'd gladly do 3 months for grievous bodily harm.
Sorry to hear about your loss man.
Let's hope for a miracle and see if any Police work actually happens.
But I think you've got a better chance winning Powerball on a Saturday night.
I never park my skyline anywhere unless if I can see my car. I used to go to uni at UTS and know all too well about the cars stolen from the entertainment centre and market city. I knew of about 10 imports taken there over the 5 years I was at uni (and they were people from uni, so there were probably more than that).
I'm even paranoid about my stagea daily.
that's terrible, i thought i was paranoid before, but now...
so what can people do to protect their cars without several years learning to be an auto electrician? i had a mate who decided for some extra protection to run the ignition through the cigarette lighter as a crude immobiliser lol.
can a hidden kill-switch be bypassed easily?
perhaps hooking a crossbow up pointed at the window would do it...
hey guys im an electrician by trade and know a small amount about kill switchs in cars. i run a full battery isolator on my car but thats more to do with the track use rather than security (its a track car). its a large red plastic key that needs to be engaged next to the battery in the boot of my 33. without this key in place the battery is completly isolated from the cars electrics.
i can easy think of a way around this right now but i wont list it in case there is any scum trawling the forums looking for ways around it.
i have helped my mate put a hidden kill switch in two of his daily driven imports (r32 and s13)
it was as simple as locating the fuel pump wire and putting a switch inline. this wire usually runs in a fairly easy to get to place but is well out of eye sight to anyone who didn't know it was there. (once again i wont list the wire location in case car thieves are reading this)
i can think of plenty of other wires that putting a switch on would hinder the car being driven.
on older cars u can simply take off the lead from the coil to the centre of the distributer.
u could have a quick release steering wheel as one of my mates has.
if your willing to remove the passenger footwell scuff panel u could take your ecu every time you leave your car lol.
you could carry surclip plies and take the gear stick every time u jump out lol.
hidden switch for igniter on early nissans (newer ones have igniter built into ecu)
Yep fuel pump kill switch is one of the best bang for bucks you can do for car security. Extending the wires to the switch also allows you to the mount the switch where ever the hell you want.
Hope you get some information about your car one day buddy.
Edited by PM-R33
Damn thieves are making it REALLY hard for people to enjoy their cars. My last car I hardly drove it because I was scared to take it out and leave it in the parking lot. I hope the person responsible gets what's coming to them...
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
