I totally agree with whatsisname. I am expericencing the same problems with my stock ECU as its starting to show its limits. At a dyno day, the graph was climbing rapidly, then it nosedived by about 30kw, then rocketed back up to close to 170rwkw. There was no doubt the ECU was pulling timing badly. On the road, it was like I was backing off, then flooring it again. After that, the curve was smooth again, with 1 deg less on the base timing. I am thinking of doing the knock sensor mod so the ECU doesnt panic all the time..
in regards to the AFR's, on graphs ive seen with the stock AFM, the line is more up and down and messy looking before leveling out in the top end. I just had my car tuned with a Z32 AFM and the AFRs are HEAPS smoother and flatter. Maybe they are easier to get consistent with a Z32 AFM? i dont know. i dont really care either, as long as its safe and the car goes hard is all that matters!
Well done, new found power is awesome!
Enrico,
Why can't shootout accredited dyno's be compared? I take it this was a Dyno Dynamics dyno? I've seen hundreds of cars using 4th gear and they don't hit the speed limiter on the dyno, what's different about there's? I totally agree that dyno's are a tuning tool, and that aslong as the tune is good then that's all that really matters, but it's nice to have a final reading in shootout mode so that we can all compare figures without dyno bias.
enrico i doubt your AFM is maxing out at that power. With the boost your running and the power your making it should be absolutely no problem. My stock AFM only maxed out running 18psi boost on a cold night. I could almost get away with running full boost in warmer temps with the stock AFM. Mine with the stock AFM made around 230rwkw without maxing out (unless cold air temp).
Seeing as Z32 AFMs arent real cheap, plus if you do change it, you will need a retune on your uni chip, id be sticking with the stockie until it brings you problems.
Steve is their a way to work out what voltage the stock AFM is running out without getting a fancy aftermarket computer ?
Also remind me please, what is the peak voltage again for a S1 AFM ?
peak voltage is the same for all AFAIK, S1, S2 and Z32 - 5.115V, not sure how you would check it sorry, must be some way to measure the ouput though
the difference between skyline and z32 is what airflow produces the same voltage, z32 will flow more air for the same voltage reading as a skyline afm, so for example (figure purely for demonstration) the airflow for a skyline afm may read 5.115V, but the z32 may only read 4.25V. thus greater tuning ability at higher airflow
Gts-t Vspec, I will be gettin a figure from tilbrooks when the boost is upped and cam gear is dialled in. But until then, u will have to wait. Of course I would like a dyno read out in shootout mode, cos i know on this particular dyno, it is one of the lowest reading in SA. So obvioulsy i want a higher reading :D So i can compare to u.
Also, how come whatisname commented that our dynos were very similar in curve, then he mentioned that he was maxing out afm. Thats what has gotten me confused.
Another thing, Last night while driving (9ish), the car felt good, but when i was drivin another hour or so later (11.30), it felt awesome, like heaps more pulling power. Could this be what you guys state at maxin out afm, or would i feel it in a jerk of some sort. Or it could of been cos the colder air..
Do you know if anything can be plugged in on a dyno and tested that way? I wouldn't mind knowing what mine is running at just to see if its causing a bottleneck.
A real budget way, is next time you are on a dyno, just use a multimeter to measure the voltage output from the signal line on your AFM...or perhaps more conveniently get a cheap batter voltage gauge (Jaycar???) and wire it up, you will soon know what its peaking at, some of the cheaper voltage gauges may even have a peak recall.
Haha the thing is Benm, u cant compare dynos, just how u have experience with some readin 203 for u then others at 180...
I dont see how people can still think they are compareable. Anyway, ill just use my digi multimeter and see what happens on a dyno run.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
