  • Replies 50
My understanding is that the atessa sends 5% drive to the front wheels as a minimum at at all times.
Regarding fluids when my car was auto I bought 20L of quality synthetic atf and used it in the auto, the atessa and the power steering.
Well just as abit of of an update with my car, took it to a GTR doctor xD, got all the fluids in the car changed, $600+ of fluids! Both diffs, transfer case, gearbox, ATTESA actuator.. everything done except a coolant flush which is getting done next time i'm there.
My mechanic belives that it is most likely a G sensor. However upon driving he believes that there is something abit wrong with the speedo.. When accelerating it stays on 0kph then quickly rises to say 40kph, the delay is minimal however he belives that this could also cause my issue. As the ATTESA takes inputs from the G sensors, speedo etc right? So if there is a delay, the ATTESSA might be tricked into believeing there is wheelspin.
Any chance of this being the cause? I plan to get it looked at again in the near future!
Looking at the R32 RB26DETT System Figure, the ECCS unit gets its' vehicle speed signal from the speedo which gets it from the gearbox.
I can't find a diagram for the R32 ABS/ETS unit but I would imagine that the system is only looking at differential readings from the ABS sensors.. will have a look when I get home.
Edited by bubba
Yeah it looks like the ECU gets the vehicle speed from the speedo (for speed limiter etc) but it also looks like the ECU only supplies the ETS (attessa) with throttle signal and engine RPM, I guess the ABS sensors would be providing the speed for the ETS computer. If you end up needing another speedo with speed sensor let me know, i've a spare.
Roger that doo doo!
Is it possible to repair the speedo without changing the cluster.. as i believe my car has genuine k's and would like to keep the "standard" ODO on there if possible.
If it is something as simple as this to fix my problem that would be a massive relief!
I had pulsing issue where if the car was cruising around 100km, I could feel the car surging forward slightly every 5 secs or so constantly
at the time if didnt put 2 n 2 together as I was only fixing the flicking needle but it also sorted out the surge as well
Hm my issue occurs at 100kph as well, not sure if mine "surges" .. the torque just goes foward after a certain amount of time.
I will have to get this fixed asap and see if it solves my problem:D
The 'speed warning' unit which looks like a fuse is interchangeable between speedos so you can keep your original cluster. Still don't know if it supplies speed info for ECU or if it's just a limiter warning or power steering/hicas input. If it's jiggered it might be doing something funny to your attessa at 100kph, but check the speedo cable first. After the G sensor of course
are you 100% sure the tyres are all the same???
do a liltle test, put the tyres on the front on the back and back on the front, than go for a drive and see if it is the same.... if it dose than its a prob with the 4wd system, theres a test you can also do its in the workshop manaul mite be worth alook
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
