all stock, raise the boost on the 32s rb26 and it should be a different story. cant do much with na =(
Oh buddy, theres pleanty you can do!
VQ35HR, 6 throttles with tuned length intake runners, decent mandrel bent headers, high flow exhaust, aftermarket ecu with VVT control. = 360 - 380Hp depending on quality of execution? :)
Edited by chad bob
I was actually hoping that the v35 will do better. Again the brakes seems to be fading after 3 laps just like in another clip where the v35 went against some rx8s and 350z.
Yup!... That's why I love this clip.
VQ35HR, 6 throttles with tuned length intake runners, decent mandrel bent headers, high flow exhaust, aftermarket ecu with VVT control. = 360 - 380Hp depending on quality of execution? :O
http://www.350zmod.com/Jenvey-Individual-T...tb-350z-g35.htm
Unfortunately the cost to power gains ratio is far higher than FI
if u had alot of $$$ that is. the amount spent on making an NA to 360-380hp, would be better spent to FI the car. :P
and also from what i meant was...without spending a single dollar *maybe just a manual controller* you raise the boost of the 32 it will beat the v35 with ease. with the NA you cant do much...well nothing at all really if you werent going to spend any $ on it.
What Clip?? I wanna see... post it. I always love watching our cars do battle. There isn't enough of it.
Yeah you got a point mate but seriously, you're comparing Turbo VS NA... Of course a few tweeks here & there will turn the tables for the R32...
My point was that (despite the massive head start lol) a heavy stock NA-Rear-Wheel Drive 350GT was able to beat a lighter stock 4-wheel-drive R32 GTR V spec lap for lap... which deserves a thumbs up. :P True?
If any of you guys have any more Hot Version or Best Motoring clips of our 350GTs can you point me to them... Thanks.
Yes you can get more gains from a turbo motor by just winding up the boost BUT a well tuned NA is so different and sounds so awesome!
You can't go past the sound of individual throttles at full noise and the lumpy idle with a set of high duration cams is just too nice. I also think that completing the mods that I mentioned earlier would be on a par if not cheaper than a turbo / supercharger kit.
If the track was empty I think the R32 would have done a faster lap time than the V35. He was simply stuck behind him a few times.
Tyres, drivers, condition of vehicle, etc would also play a part. The R32 is 15 years older.
In any case, slightly disappointing result for the V35. Stock vs stock vs stock i thought it would be at least a little bit closer to the other cars.
Gotta agree with Brad as I was kinda disappointed as well seeing the v35 so far behind the imprezza and lancer..... was hoping to be much closer although those are 4WD cars.
Yeah, and the TS version is like $6k, seriously why bother?
Exactly. 6k is the US price just for parts. Add the rest as well as tune and supporting parts and you've gotta be nuts to build an NA V35. Or etremely rich and don't mind losing money.
i understand where you're coming bud, nothing better then pure NA sound. but like i said what i meant was *without spending any money* all that the 32 has got to do is the boost up. na no...
individual throttles....mmmmmm :thumbsup:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
