my housemate's r34 got a problem cause the car not going straight when hands off, it's going to the left.
he brought the car with this problem since 2 years ago.
he changed all new tyres and suspensions, and did a 4 wheels alignment recently, but the problem still don't go away.
the car should not been crashed and don't have any damage on the body.
anyone has any idea what's causing this problem and how to get rid of it?
cheers,
ryan
I had a problem with this when i first got my car also until i took it to my mate to align it...
the issue will be the car is aligned straight so the road camber will be throwing it to the left, what you need is some one that knows what their doing to put a slight toe-in on the front left wheel to make it drive straight.
+1 ^
Wait Brad is leaving!? :)
To the OP, could be any number of problems, my mates R32 had the wheels aligned twice by two different places, turns out it needs a camber arm kit. My car used to do it, found the front left tyre was 3psi flatter than the rest of the tyres, pumped it up and problem fixed. Although it still does it on the freeway which leads me to believe it is the camber of the road causing it.
Do you have a previous wheel alignment print out??
If you do, get it in your hand and give me a call as there is some info on it im curious about.
(WA Suspensions 9444 0500)
Also, castor rod bushes...have they been changed or are they still standard hydraulic ones?
Camber of the road can and will affect it aswell. No one will ever make the car drive dead straight as our roads are cambered....but it can be made 'better'.
What tyres are on the car? is it a known 'decent' brand? (Bridgestone, dunlop, sumitomo, etc etc) or a cheap china brand like LingLong, Wanli, Triangle?
Just becuase there is no damage to the body does not mean the car has not gone over a kerb at a fair speed. Just for shits and giggles, measure the wheel base left and right (centre of rim to centre of rim)....whats th difference in measurement? 5-10mm can make a differnce.
Roads have camber ? :)
Yerp, very important factor in road design.
Taken from http://www.arrivealive.vic.gov.au/initiati...rovements.html:
"The camber or tilt of a road can greatly influence a car’s ability to travel safely through a curve. A poor road camber increases the risks of vehicles running off the road. The road’s camber will be improved at locations where it is associated with a high number of fatality or serious injury crashes."
*EDIT* Also what Brad said about water drainage etc.
Edited by Hanaldo
thanks everyone.
the tyre pressures is good, and they are continental, so shouldn't because of the tyres i think.
i know the road got camber, but even it drive on a really flat surface that every car can go straight, it just can't. :)
he did a 4 wheels alignment 3 weeks ago at WESTATE AUTOBAHN in Newcastle Street, Perth.
we droped the car there and 3 hours later they call my friend siad the car is ready to pick up and it is all good. they didn't point out any thing at all...and the car still going to the left...
castor rod bushes haven't been changed. they can be contributed to this problem as well?
cheers,
ryan
I took my car to Peddars when I first got it for an alignment and 28 point safety inspection, they got all freaked out and flustered working on an import, told me my whole rear suspension setup was f**ked, would need to replace the whole thing, they quoted me $5000 ffs.
Took it to WA Suspension for a second opinion, Brad called me back after about an hour and said it's really not that bad, there was some slight play in the rear sub-frame bushes that could be fixed with some pineapple bushes. Got the work done, ended up costing me about $560 all up.
Seriously, take it somewhere where they know what they are doing (read: WA Suspension).
+1 for WA suspenders.
Had them knock up an alignment for Teh Fury yesterday, and was forced to stop twice on the way to home so I could get out and roll naked across the bonnet. I dont think the chick at the drive through coffee place will ever serve me again though :P
Hmm, turns out that there wasn't enough castor on the left front wheel so we chucked in some castor bushes and she is all sweet, $200 later problem is solved :) if anyone else is having a similar issue feel free to give us a call :(
Dale i got to drive Teh Fury back from Allans CV's, man it was terrible to drive, pulled left like a bitch, all good now though?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
