  • Replies 74
have an update guys
after fitting my controller i set the boost to 8 psi ish, and now when giving it juice it starts to POP after around 4 or 5k rpm, it feels like it his redline and dosent want to gain anymore rpm and goes pop pop pop pop pop pop untill i back off, the boost dosent creep past 10 psi when this happens so it must be something with the engine, any ideas?
that sounds like R&R now
are you sure you are setting it to 8psi and not reading 0.8kgcm2 on the stock guage?
0.8kgcm2 or 0.8 bar is very different to 8psi
its definatly psi, the guage says psi
would r&r cause it to pop like this though? i thought it would just run slower and richer, this was like crazy popping like the rev limiter but replace the revs with pops, and wouldnt rev more
nah R&R basically just feels flat and empty
ie all the power drops off but the car keeps going
popping / farting flat out is either
detonation
misfire
detonation is from too much boost, poor spark, poor spark gap, poor fuel, poor timing, poor compression, too high intake temp
misfire is from
poor spark, poor coils, damaged coils, damaged or mangled spark wiring / loom, other electricial issues
detonation
misfire
misfire is from
do you think the above mentioned issues with a cracked coil or to large a gap for plugs would cause this?
yep, absolutely, it's a really common problem with skylines. the coilpacks often need replacing after 100k km. the popping is prob the misfire, i have the same problem.
try the above methods and see how it goes: reduce gap, tape coilpacks, silicon coilpacks, replace coilpacks (or just skip to that)
cheers mate, will try them all this weekend and report back, hoping it fixes the issue! i dont mind spending some cash on coilpacks if they need replacing though, if thats whats causing it
cheers
are you running stock ecu?
if you have full exhaust/ intake then even if you set the boost to 8 it's gonna creep past that no matter what. r33 ecu's are very finicky. so hell maybe its just creeping to 9psi.
that could still cause it to go into r&R.
oh, i didnt know that it will creep no matter what with the mods...
i have
3 inch bellmouth, high flow cat, 3.5 inch cat back
normal airbox with k&n filter
fmic
stock ecu (i think, i might have to make sure)
i always thought it was something wrong because, theres a limiter, weather it be the actuator, or the boost controller, that it limits the pressure by releasing the flap, so i just dont understand how it can over pressurize
Just to add my experience to this, maybe it will help someone or someone can help me.
I have an R33 manual.
- 3inch belmouth dump pipe, xforce cat (dont know how old it is?), 3inch stainless sytem
- Pod filter
- R34 SMIC (cleaned it out as well as the piping.
My car has developed a bit of a flat spot on really cold nights (worse with fog) so its probably getting to R&R point.
Interestingly my boost gauge (psi) only reads 7max! according to everyone i should be getting more than that?
thoughts?
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
