  • Replies 49
hey,
sorry for not having a general enquiry on the car, but just wondering what offsets you're running as well as tyre sizes. Do you have any trouble with the wheels? (rubbing, scraping on full lock)
cheers
18 x 9 +15 and 18 x 10 +22. 225/40/18 front, and 235/45/18 rear. Had a little scraping on front inner guards but nothing that cant be fixed.
Heyo... If that beautiful machine is still on the market let me know.
As my R33 was kidnaped presume murderd, it looks like i need me some wheels.
Ill have a chat with the Boss Lady maybe we can come have a look?
Cheers
ok ok....That is a nice car! :D
Thanks for letting this newb have a look.
I will get back to ya later this week.
Deep down im hoping the guys from pimp my ride will show up and give me my car back with some wacked out mods.
(Or a call from the cops saying they found it)
Either way speak to ya soon.
Cheers Mate
BUMP!
Cheers Mate
BUMP!
nah you dont want your old boat back... trust me as a fellow 34 owner and knowing this guy and how he has treated this car YOU WANT this car!!!
Cheers Mate
BUMP!
+1 to that
Just waiting on the insurance claim ...... but your car is still on top of the list.
I will give ya a buzz on the weekend chief.
Regardless of the result THIS IS A SWEET CLEAN RIDE cant believe its still for sale.
Well worth a BUMP> :D
lol...
u may want to look in to that importing an s14 idea a little more before u go selling ur car for it
lol.....
i already bought an S14 here locally. Thanks for the bump.
Car is still for sale guys!
Again i just gotta say this is a great car... Damo is a solid bloke and i was so close to buying this machine, i could taste it!
Its well worth a look for anyone who is after a well maintained car.
For the record im signed up for a V35 GT 4dr due to practical reasons....
But i gotta say i love this car....
BUMPED!
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
