Hi, This is probably a stupid question, but im currenlty searching for an R32 GTR and ive noticed that there are a lot of different kinds of R32,
so far i have seen:
BNR32
HR32
HCR32
I asked a mate and he said that HCR32s are only single Turbo and BNR32s are Twin, but this doesent explain what an HCR32 is..
if anyone knows the difference i would be really interested in knowing
cheers in advance
https://www.sau.com.au/forums/topic/330022-difference-between-r32s/
you must be a right noob. but hey we all were once. i'll lay it out nice and simple.
BNR32 = GTR. 2.6ltr rb26dett (twin turbo) 4wd.
HNR32 = GTS4. 2.0liter rb20det (single turbo) 4wd.
HCR32 = GTS/GTS-T. rear wheel drive, hicas equipped. turbo or non turbo.
HR32 = GXI/GXE/GTS. no turbo, no hicas.
  • 4 years later...
Well not as simple as that, but at the end of the day pretty much everything can be swapped.
The brake swap needs 5 stud conversion though.
You are going to struggle to find a comprehensive list explaining it all though.
