Hi all im new to the forum,
I have got a 98 model r33 gtst and i am about to change my timing belt, tensioner, idler and all that. im just wondering if anyone has done it before and if there is any tips and tricks for doing it and any no no's? Im doing the 100,000km service bought all the stuff already just gotta do it.
https://www.sau.com.au/forums/topic/330430-help-timing-belt-service/
if your gonna hold onto the car its worth doin the waterpump aswell. think it was 120 from nissan and is behind all that. mine started leaking from tell tale about 120,000 and saves pulling it apart again
yeah iv got the the cam seals, yeah i would but going over seas for a hol at the end of the year so i cant afford to spend much on my car this year other wise i would stick on my t4 turbo.
T4 turbo? eh
Check the timing after you're done with a timing light. Something I didn't when my timing belt was done, and the guy that did my belt didn't know it either appereantly. Someone gave me the tip, went and got it checked. Timing was at 21 degrees, while the RB25DET is supposed to have a timing of 15 degrees.
+1. I have the same issue which is getting fixed at the end of this week. The timing belt was done on my R33 and the timing was set to 10 degrees for some reason. As far as I am aware a manual RB25DET is 15 degrees and an auto RB25DET is 20 degrees.
Tips:...
*Mark the valve timing
*Seal the water pump good
*Make sure cam / crank seals are in 100%
*Check ignition timing afterwards
*Once the new belt is on, turn the motor over 2-3 times
*Locite on the crank bolt and make sure its tight!
*If you can, torque the bolts
*Make sure belt tension is correct
Thats all I can think off atm. :/
how do i suppose to tell how many degrees is mine in?? becoz i just changed my timing belt recently too and i notice my gear ratio is a bit different when i change gears, the acceleration goes up more than usual everytime i step it i guess??
Easiest way is to go to a garage that uses a timing light. Shouldn't be expensive, and done in a matter of minutes. The timing is adjusted through the CAS, and it's really a matter of millimeters, so if you're not sure about what you're doing, let someone else do it. When the timing is really off, it can do some nasty things to your motor in the long run.
sweet, that might be a good idea then, take it to a mechanic to get the timing checked once iv changed the timing belt. This might be a stupid question but is the cas the comp in the car or what? Im not bad when it comes to hand on shit seeing as im a aircraft mechanic and i should be seeing as i do it everyday haha but when it comes to other shit im hopeless haha. Thanks for all your help.
  • 5 weeks later...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
