oh i thought you'd change the coilpacks already....
the #1 place to check first is coilpacks. Get splitfires if you need to change them.
Does the car sound audible different when you hit the flat spot? any engine check lights come on?
OK -
CAR IS STOCK - Only pod and exhaust put on, No coil packs nothing>
Now my mate said all his skylines he brought has done the same thing,
APPARENTLY spit fire coil packs are the answer.
It has nothing to do with timing belt as the belt had just been replaced 4 days ago. and major engien service.
No engien lights are coming on.
When it hits second stage boost, the rpm tacho goes mental. ( showing mis fireing ) this i belive is due to SHIT COIL PACKS ( standerd)
I am buying spit fire ones to solve the whole problem.
Hope it works.
I don't think you understand, it could have everything to do with the timing belt being changed if they've skipped a tooth during installation.
Get them to check that first. The try the other suggestions if that fails. Generally if you start having issues after you've just replaced a part the best place to start is looking at the part you just replaced.
You didn't say anything about misfiring before...where was that gem of a symptom when we needed it :(
so n that case do u think it may be coil packs? ive been advised by a mate who had very simalar happen to him on both his gtst and his new gtr he said he just changed coild packs straight up and works a treat now.
whilst it's a very good idea to check the timing, there probably isn't any harm in changing the stock coilpacks anyway. Yes some peoples last, but you'll probably need them sooner or later anyway.
Coy
Ill
Paks.
The taco jumping around is a dead give away.
Get yourself some new coil packs. JJR (Just Jap Racing) coil packs are about $100 cheaper than Splitfires and have had many good reports. JJR are traders here - find them int he Classifieds section.
Yeah if you can afford to do so, change the coil packs regardless of what this issue is...they fault down the track even if they aren't responsible for this. But I suspect they are...
You have a choice of:
Splitfires
Yellow Jackets
Just Jap Racing
There's a few other brands floating around too but the above have been used pretty widely on here with good results.
Make sure they hooked up the cooler piping tight aswell, as a leak will make it run rich and miss if they touched it. Also check turb boost line, Map sensor line and bov line.
Does it miss under non boost accel to the redline?
im looking at used spit fires or brand new yellow jackets.
um i donno it idles funny, then when boost kicks in it cuts out after 4500prms, then run like ass untill 6000rom and then boost kicks back in again?....
i donno i havent even taken the car in to get checked up it so ill figure it out.
its got stock cooler piping but i guess i shall check all hose clamps after i get my coils.
All vaccume lines and press lines including BOV seem to b in good condition and all conected properly.
It just feels like the engien is not fireing properly. or not breathing properly.
think ill get coils done then timeing re done and go from there, im prety sure it should solve the problem.
if your coilpacks are shagged, they are shagged all the time on boost
ie they dont magically work between 4500rpm and 6000rpm and then misfire city
when coilpacks are shagged it will misfire its ass off from like 3000rpm to redline (any amount of decent boost)
given you mention the typical flat spot / cut range for R&R id say check the basics
given you said youve only just had the car
it could be
a) it started since the service / timing belt,
or b) its always been shagged
so check the basics, check it with a timing light at idle, check to make sure your base timing is correct
reset the stock ecu, perform a stock ecu diag if you can with consult to check for any dead sensors or unplugged sensors
best thing is just to check in with a reputable workshop asap - patto i assume is patterson river, so take your pick of say Chasers east, RE Customs etc.... I'd def go to Status but they won't be back until 30th August, and i take it you'd probably want it sorted by then.
and IF you do need coilpacks, DON'T muck around with the other brands - just get splitfires.
Why do you keep saying this? Have you had a bad experience with other brands?
Yeah I gotta ask, do you work for splirfire lol? They aren't the only ones who know how to make coil packs :nyaanyaa:
All coil pack brands (including splitfire) have had warranty issues, and from what I've seen replaced them for the customer without hassle. YJs saved me and a few mates $200...
:nyaanyaa:*************PROBLEM FIXED PEOPLE!!************* :P
Issue; AFM, Was corrupt. Replaced with new one- CAR RUNS PERFECT>
Thankyou all for ur suggestions. In future any further problems i know where to start looking!
:P*************PROBLEM FIXED PEOPLE!!************* :D
Damn it!
Sounded like coilpacks to me :nyaanyaa:
Glad you got it solvered :D
Yeah I gotta ask, do you work for splirfire lol? They aren't the only ones who know how to make coil packs :D
Exactly, I am using Branz coilpacks they work great, about 15 months of use thus far no issues with 270rwkw.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
