Well, I'm looking at getting some decent coilovers for an R32 GTS-t, and would like some recommendations.
At the moment, I'm looking at the APEXi WS coilovers ($2700), or the Tein HA kit ($2200). I'm leaning towards the APEXi's, but I'm not sure whether they are damper adjustable like the Teins' are.
https://www.sau.com.au/forums/topic/33064-budget-coilovers/
Hi Elitharar, a previous post on Japanese coil overs..........
In general I find Japanese aftermarket spring rates to be too high. For example our R32 GTST arrived with 550 lb springs in the front and 300 lbs in the rear and it was a road car. For circuit racing (on "R" Type Tyres) we have reduced even these, too hard for bumpy Australian tracks. On the road it would be a joke.
There are lots of reasons why, but the main one is, the Japanese have never heard of upgrading the anti roll bars. They don't have our aftermarket history (no KMac or Selbys). So they use these ridiculously high spring rates to control the roll, which is the anti roll bar's job, not the spring's.
Shock absorber technology for supplementing soft spring rates is also something that totally eludes them, the Europeans have it, particularly the Dutch (Koni legacy) and the Germans (Bilstein). Although the Scando's (Ohlins) are arguably heading the pack. The Yanks, as usual, fall for the trap of attempting to over engineer it (Penske). Even the Ausies (Murray's Proflex for example) are way better than the Japs. For the money Jamie's DMS's are far better than the equivalent cost in Jap stuff.
Bottom line, I don't like the typical Japanese spring rates and the shocks are grossly overpriced for their underlying technology. But they are nicely made, very shiney.
So I would go for Konis or Bilsteins with a Whiteline coil over kit. If you want the next step up, they have their new Group 4 coil over setup (engineered in Europe).
Have a look at the Skyline suspension articles at
www.whiteline.com.au
Hope that helps
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-664100
my tein coil-overs are suprisingly not too hard and feel good tho.i got it second hand in good condition pretty cheaply
What Tein's are they?
I'd definitely be getting the coilovers without the pillow upper mounts.
http://www.tein.co.jp/hadampe.html - On the softest setting, the damper rates are supposedly only a few degrees off what the standard rates are. The spring rates as stated as UAS: F:65mm(diameter) 8.0k/200mm R: 65mm(diameter) 7.0k/250mm
The Whiteline springs look pretty nice, though they cost about $1500 more than the Teins.
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-665966
Hi Elithar, 8.0k is 8 kilograms per mm, that's 450 lbs per inch at the front. That's 50 lbs more than we run in a circuit race car. The rears at 7.0 kg per mm are 400 lbs. That's 150 lbs more than we run in a circuit race car.
If the shocks are only "a few degrees off what the standard rates are" then they have no hope of controlling this rate of spring.
The Whiteline kit you are looking at is Group 4, that is their most expensive range. If you want cheaper from Whiteline you can get Koni adjustables with a coil over kit for around the same as Teins. Give them a call 02 9603 0111 and speak to Wedge.
Hope that helps
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-667064
Got a reply; they've recommended the Handling Pack to me. Coupling that with a pair of springs to lower the ride height seems the most cost-effective option; and, most importantly, it will allow me to spend money elsewhere (exhaust, intake). Should cost me around $1200.
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-668377
i bought and installed some TEIN HA coilovers in my R33 and they are awsome, yes there stiff, round town and stuff you really feel the bumps.....but when pushing the cars through the twisties....you can tell where your money went!!! and as far as spring rates go (i was unaware of this till after purchasing) I think you can specify what rates you want (or choose from a list?) your set to come with? not 100% sure, but it does specify different spring rates in the manual's i recieced with them (all in Japanese by the way).
I was lookind at Apexi ones too before I went the teins...now Im glad i did
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-669923
you mean they recommend that you change all 4 springs and keep the standard shocks? the $1200 includes sway bars and such too right?
i wanna improve on my handling as well and sydneykid has been giving me lotsa good advice.
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-670356
No, Whiteline recommended the Handling Pack, though I also wanted to get the springs (same ones as the Sports Pack). Probably not the best idea with the standard shocks.
Check out the document here; it has all of the part numbers and prices. $615 (+ $275 fitting) for the Handling Pack, and $1339 (+ $225) for the Sport. Combining them will give you 'the Works', and that is $1850 (+ $450).
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-670630
Has anyone used coilover units built by GSA or Fulcrum? They are basically King Springs, and bilstein/koni shocks built into a coilover unit. Any opinions of these? Supplied price is about $1800-$2200 depending who you speak to.
I'm looking for some coilover options for my R33 GTS-25T:)
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-672183
  • 3 months later...
Dont be too concerned about using the Whiteline springs with the std shocks.
I went to Whiteline a few years ago with a std R32GTST with King Springs. It handled ok but nothing special. It felt like it handled until you asked it to really corner then it was woeful :Oops:
So Whiteline put their handling kit on the car, ie swaybars, bushes, strut braces and wheel alignment and the car handled GREAT, while still being completely comfortable on the road due to the standard shocks and King Springs. I drove the car around like this for about 4 weeks until the Bilsteins and Whiteline springs arrived, then they went in as well.
The difference with the Bilstein/Whiteline spring was noticeable from a ride and handling aspect (im talking full tilt thru corners, not pottering around at normal speeds) but the difference was nowhere near as dramatic as the swaybar/bush/strut brace upgrade.
So id give the swaybars, strut braces and bush kit (does the handling kit include front strut brace?) combined with just the Whiteline springs with std shocks the BIG THUMBS UP.:rofl:
When your std shocks call it a day, or more funds become available then i would look at the Bilsteins or Konis then
...oh and isnt that R32 on the Whiteline pdf file the best looking R32 GTST ever, ;)
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-871452
I was definitely thinking at least the springs and bushes (pineapples, camber kit, etc.) first off; and it looks like the handling pack will be a good investment soon after. Not so sure about the shocks yet, as I might invest in some Tein's after I get some funds. From my rather limited experience with Jap. coilovers (and coilovers period), I'm quite impressed. Ride quality wasn't harsh at all IMO.
https://www.sau.com.au/forums/topic/33064-budget-coilovers/#findComment-871568
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
