help, I went to get grocerys and when I went to drive home, started the stag up,,, it idled really low and was fighting not to stall, then cleared up but wont go over like 2.3k or so,, just like its hitting limiter,, really nead help guys
https://www.sau.com.au/forums/topic/330649-help-engine-wont-go-over-2k-rpm/
  • Replies 42
Sounds like you need to visit a tuner mate. Tell them the symptoms and they can plug in their diagnostic software and suggest the fix.
Another method is to borrow someone elses AFM from an M35 and plug that in place of yours.
Moisture in the AFM?
I'm not sure about M35's but most AFM are hot wire. They have a limited life due to the thermal cycles they go though. You might have even gone over a speed hump and it may have broken. The only way you can find out if they are good or bad is diagnostic software or replace it with a working version.
more than likely it's the AFM....mine died two weeks ago for no reason as well.
Get the codes.....pretty sure you can get an second hand x-trail one.....or you can go for the 1 year warranty approach and buy a new one....Hornsby Nissan had em in stock....get a price from them I'll see if I can beat it.
Thanks everyone. Fault code 0100. Took a couple of tries to get it to flash, bu got it in the end.
Now to see about getting a new afm. Anyone know where is good to go? Nissan is one. Any other.
I have an s2 afm I'm selling I'll pm u
Arnt wc34 and m35 different?
some of the C34 guys get a little confused.....I give you a heads up as they don't quite get it :nyaanyaa:......our car is 98% different to the C34! So when you hear the line "Well on my C34......" more than likely they are completely wrong with the assessment!
Sorry in advance if I have offended any C34 owners :P
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
