well would be at least 6 months and maybe $1000 fine.
I'm wondering why 'for legal reasons' he cannot be named/commented on? That doesn't make any sense to me that he's able to obtain a suppression order or something I would like to know how.
Although I would have thought this would have occurred Saturday night...
If its his first time getting caught its $500 fine 6 month license suspension and 1 month car impounded
Just because he was booked doesn't mean that WAPOL or DPP will follow through. I've seen them get away with assault caught on camera with only a reprimand.
I'm also speaking from experience.
Wow dude. It seems you have a story for everything. Just how many times have you had a run in with the law?
A story for everything, since when? Where have I stated that I have had run in's with the law? It seems you're getting somewhat defensive about people commenting about police. Do you work for them in some way?
I was bashed by a cop when I was 16 in the 80's and the bastard got away with it. A mate was provoking one when he was drunk one night and I copped it just because I was with him. I was even trying to shut him up. I even remember his name, would you like that too?
This didn't leave me with a scar to the extent that I dislike police just because of one tosser. That came 9 years ago after I bought my first HPV.
No one is getting defensive mate :/ Settle down.
He should be treated the same as everyone else
That also means he shouldn't loose his job
Be cool seeing a Police car driving around with "E" plates on :D
(Can someone photo shop me so I can visualise it?)
There u go bud. Only a 2 second job though  :)
I am still surprised they even wrote him up i thought cops had some sort of secret code. Just found this comment relating to letting him leave with the car.
[Acting Assistant Commissioner Michelle Fyfe denied the officer had been given preferential treatment by not having his car seized immediately after the speeding offense.
“(The surrender notice) is a new sanction that has been brought in,” she said. “Since January 1, nearly 500 people have been afforded that opportunity. ]
Edited by R33 GTS TURBO
There is a secret code but not for random knuckleheads breaking the limit by such a large margin. It is reasonable to expect that a charge of this nature, if found to be proven, would be career limiting. I imagine redepolyment to another district (somewhere sunny lol) and a poor promotion prospects. Not to mention the verbal he will take from his collegues.
In the long run this charge would be difficult to come back from
In a career that requires you to have a license I would see no reason why he couldn't be sacked if he's unable to perform his normal work duties.
I guess he'll be desk bound for the next 6months :domokun:
He deserves to be fired and be plastered all over the media, seriously what example is he setting for us young people when we see those in the power, position and respect doing things like this, it gives me the idea that it is ok to do it myself.... obviously this is sarcasim as i know right from wrong but think of the children :domokun:
^ i would like to know how to do this just in the event it happens to me.
well the cop getting done for hooning makes me think he must have been doing something extremely stupid other wise they would have looked the other way. so i vote he should be raped by the hoon law and fired because dont u need a drivers license to be a cop. and what there probs going to put him on desk duty thats BS if i lost my license i wouldn't be able to attend tafe and get to RPH among other things so he should get fired.
Sources tell me there was a proby present and therefore an example would have needed to have been made.
If he was done by a camera then he would also have had the book thrown at him. It would have been the big wigs who told the media in order to illustrate parity in the law.
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
