Ok guys, just pulled my turbos off (no jokes pls!!!).. There pretty laggy, I got them with my 26, stated as having STD turbos on it.. so a bit of a win I guess..
CHRA has 14411-06U00, which is apparently r32 gismo turbo's, thus explaining why they're laggy...!
Now the thing I don't understand is the nismo's are meant to have a 0.42 compressor, but these are 0.6 like on the GT/le mans nismo's, but the CHRA doesn't show 14411-rs581 as per the lemans turbos.
Confused.. Any help appreciated, would also like to know their max power and efficiency range.
Also, have stock bottom end, nismo 555cc's, microtech, walbro, etc.. If that helps
Thx, Chris.
Edited by kristafa
https://www.sau.com.au/forums/topic/330745-can-you-name-these-turbos/
Thanks mate, unfortunately those are the main sources of my confusion.. Why does that chart say my turbos should be .42 compressor when mine are .60?
The gtr.co.uk site doesn't answer that guys first question, ie what are they.
am I just to assume mine are gismo GT/Lemans turbos even tho it doesn't have rs581 on the CHRA?
also before anyone gets in with "these are poor design, 15 years old, bush bearing, etc" I know already, but unfortunately for the old RB, this is what she's stuck with for now haha...!
cheers paul - i've been running these turbos for 6 months on 12psi thinking they're stockies and that my exhaust was restrictive hence the laggyness.. good to know i can start to lean on them a little and start making up for that lag in topend power..
check my dyno sheet on the RB26 upgraded turbo thread - shows power vs RPM
EDIT: http://www.skylinesaustralia.com/forums/in...t&p=5112467
i have a less than impressive dump pipe setup which will be sorted before turbos are reinstalled, and wind the boost up to 17 pound or so with the new EBC there should be things happening a little earlier in the rev range.
Edited by kristafa
I've used this link before http://homepage.ntlworld.com/tbroom/Turbos.htm
But it's always been strange to me that all three of the various R34 N1 Turbos only produce 500ps as it says on the chart, I had always thought that there was a turbo that was bigger in the r34 n1 range, around the 600ps mark ?
you mean Nismo R1.. similar to a 34 N1 but flow more i guess:
http://cgi.ebay.com.au/NISMO-R1-560HP-BALL...=item2eaec141fd
COMPRESSOR:
- HOUSING: T3 (A/R 0.42)
- WHEEL: T3 (TRIM 55)
BEARING: BALL BEARING
TURBINE:
- HOUSING (NIJIREST): T25 (A/R 0.64)
- WHEEL (INCONEL): GT25 (TRIM 62)
ACTUATOR: REINFORCED SPRING, ADJUSTABLE ROD
MAX. EFFICIENCY: 73%
MAX. AIR PRESSURE RATIO (AT BOOST PRESSURE): 103% (1.35KG/CM2)
DESIGNED OUTPUT: 280PS(X2)
sell them (someone will buy them for sure) and get a pair of brand new ball bearing top notch GT-SS's or garrett equivs
the response you gain will far out weigh the current lag and lag penalty you have. specially on a bog stock 26
wow
ive checked your graph, that is horrible
bog stock BCNR33 on the graph below yours
looks to make its peak boost and torque spike at 113km/h around 4000rpm
vs your stock Nismo R1 or whatever they are which make peak around 5200rpm
thats horrible!!!
does your car have non 4.11 diff gears also ?
i dont think turning the boost up will help response
but freeing up the exhaust is always a good thing
but again i dont think it will shift the power band that much
your main issue is the housings needs lots of flow to wake up
you need aggressive tune, jungle juice, cam gears, aggressive tune and a good tune
if your timing and tune is anything other than spot on, youll pay for the penalty in poor response as your rears as much larger than stock
i reckon a changeover price to GT-SS or the garrett equivs (as per sig) shouldn't be too bad changeover price
you could probably keep the std dumps and still change the turbo's and come out on top light years ahead (in response)
ie
the change of turbochargers will yield a better response improvement vs changing dumps
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
