What tool are you using? Mine is 14mm and I use a torque wrench, it's easy as pie. If you're using something like a ratchet I would recommend investing in a torque wrench.. they are super handy :D
Most torque wrenches are designed for tightening use only, loading them to loosen a frozen nut will cause a loss of calibration. Use a breaker bar instead, that is what they are made for.
All good now. drain and she is running on new oil and new oil filter.
Just a question for next time. How to do stop the oil filter from leaking oil when changing oil filter. I had drain most of the oil
via the sump hole. But there was still abit dripping from the oil filter hole.
I am using Motul 4100 turbolight 10w40. Was going to try royal purple but they didnt have any.
What are people using for there engine. If you drive it just normally and no mods.
Would be good to know.
Bleh, too thick^
Try a 10w40, you'll be pleasantly surprised at the difference methinks.
No easy way about it, just hold or place rags underneath the filter. It won't damage anything it drips on, i.e. subframe and steering rack boots, so I usually just let it drip and give the components a quick wipe over afterwards. If you're pedantic about it you could use a jack to tilt the drivers side of the car up in the air so that it drains out as much as it can, then put the jack on the passenger side and tilt that side up so that when you unscrew the filter it won't spill much if at all.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
