Invest in a Dell IPS monitor and calibration software like Spyder 3 or Eye-One or Color Munki. All good devices and give you accurate colour day in day out.
I use a Dell IPS monitor as well as a second screen for browsing the web and spyder 3 software on both. Well worth it!
Same here. +1
No point spending $$$$$$$$ on camera gear, when you dont have an accurate monitor to PP your work.
  • Replies 174
bnr - WOW nicely done :D Got any more??
ta
No more for now, always interesting to go back to old photos and see what you can do with them now so will see if I can find anything else to play with.
Off to Singapore in 4 weeks to so should have some good stuff from there also
Nice photos Matt.
The photos look distorted to me in IE and firefox. Could be my cr@ppy computer at work.
How are you resizing them and where are you hosting them?
This could be the reason why they are so soft.
They've just been uploaded to picasa, and stored there, no editing of sizes or anything happened. Are you drunk again? ;_)
I'll agree, the third is a bit cluttered up and to much stuff everywhere. cheers boys.
took these at lunch yesterday. they're not crazy angles or anything special. They're kind of important though, first time i knew exactly what I wanted to do, how to light and set the car out, how to shoot. Precission ;p Took about 10 minutes to set up and shoot, then about 5 minutes in photoshop to increase contrast and add a sharpen after resizing. I think it's time to get serious about shooting people's cars now.
Nice pics matt. I wish i was drunk.
You have your own site why don't you host them yourselfs? Picasa could be compressing them, never know.
On a side note, if anyone here owns a Canon 40D or 50D, view my thread HERE if you want some awesome batteries!
HDR seems to be the in thing right now.. heres some of mine from the quit targa west start last friday in the city
This one is from Kulumunda service park
Zig Zag Stage:
And the outright winner, Peter Major in his awesome R35 GTR
Have a heap of photos to go through from Sat and Sun and they will slowly be added to the Targa West 2010 gallery here:
http://nextgenphotography.zenfolio.com/p889762662
Cheers :D
Edited by bnr#@
I must say i'm not a fan of HDR photos of cars. They just bring out way too much detail and ruins it for me, but that's just my personal opinion. If it's done nicely and not over-done it's ok, but most just pull too much detail out of the reflections in the paint. But i like the composition :)
