Shifting Techniques
  • Replies 45
i agree dont use the clutch and match the revs especially on upshifts (as its way easier) and on down shifts if you cant get it without the clutch or your lazy (me) ,match the revs close and only dip the cluth 1/4- 1/2 way. Matching the revs means your synchros hardly have to do any work but if you get it rong all the time you might end up with no teeth on your gearset!!!
Funkeymonkey next time you drive a ****ter car on an up shift pull it out of gear with out the clutch and as the revs are dieing apply a litte pressure on the next gear at the right revs you will feel the stick go light then push it in fast and thats how you change without the clutch!! Try on a straight change rather than a dogleg until you get the hang!!(ie 3-4 rather than 2-3)
To the origanal question hype you could get your gearbox rebuilt with double synchros ( only applies to some gearboxes) you can get special synchros that are like have two on each gear i cant remember exactly what they call them at the moment, you could also maybe get the gears angled which would make it like straight cut gears but not as severe once again you can only do this with certain boxes hope this helps
  • 7 months later...
Double clutching is depressing the clutch, shifting out of the gear and into neutral, releasing the clutch, giving the engine a squirt on the accelerator - or not depending on your technique, then depressing the clutch again and selecting the next gear. Double clutch - as in you do the clutch action twice.
Heel and toe is used on down shifting while braking, right foot on the brakes, then you want to change down a gear at the same time. So you put use your left foot to depress the clutch, then with you right toes still riding the brakes swivle your foot to give the accelerator a squirt - and try to match the revs to what they will bein the next gear, with your heel whilst changing gears, then release the clutch...
they just are :) maybe because they can growl..
hate to think how much an aftermarket gearbox is - standard one is expensive enough to replace!
I dunno.. I think the R33 box is pretty much smooth as silk.. so little effort required. Couple of my synchros aren't perfect, but generally shmick as. Some redline oil will probably fix that one day.
Top thread guys, great to see all the input.
PeakRPM, Interesting idea about getting someone to teach performance car gear changing, do you have a suggestion about who might be able to do it (ie, not a road car driving school)? I think this is a skill a lot of us should improve on, wouldn't mind organising a training day of some sort:
show/discuss gearbox internals
heel toeing
double clutching
changing without clutch
and plenty of practice and feedback.
then, if possible, some samples of other gearboxes - bog box, sequential etc.
I've done advanced/racing courses before but they mix in how to drive around a track and don't have a focus on gear changes.
double clutch the when just driving around normally. This gives the synchros in the 'box time to 'catch up' and should give you less wear. Then when you're going for it, you can just plain shift - just gives your synchros a longer life. Get the double clutch tech right and you will use it all the time; my old BM had a dodgy 'box and i had to double clutch all the time - now it is second nature... and yes, you can shift (almost) as fast... still throws flames between gears too :P
Double clutching is more for the gearbox than the clutch. the idea is that when you have the clutch up and the box in neutral - between gears, that you spin up the gearbox internals. Kind of doing the syncros job for them, or making it easier on the syncros anyway.
Heel and toeing is basically a technique developed for racing, ie. the car is braking so hard already that any attitional engine braking would make some of the wheels lock up, so you match the revs to the speed and gear to avoid any engine braking.
I started playing around with these techniques on the street just for fun and find myself doing it more and more now. Heel and toe into a quiet round-a-bout blast through it a feel like a race car driver...
Dog Boxes use dog engagement rings instead of syncros. THey are a lot clunkier and harder (read more force applied) to shift into gear, especailly at slower speeds. THey are much much stronger than ur typical gearbox though. Don't bother wasting ur time wit sequential boxes unless u gonna have the money to rebuild or replace it quite often.
Hey, magic, that actually works! good description.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
