Krishy, that would have been Brent? He is the comp sec. I assume that would be filling in the full entry form for the sprint (Which was held back until the supp regs that are attached to it were approved by CAMS)
Which leads me on to your post Matty. The supp regs and formal sprint entry form are now available as a PDF on the Skynats website. Link here.. http://www.skylinenationals.com/Entry_and_...ls_12_09_10.pdf
It would be preferable for these to be back with CSA prior to the event as the less of these we have to deal with on Sunday the better off everyone will be and the quicker we get out on to the track to have our fun.
Ahh thanks for clearing that up for me Paul...i can certainly fill out the CAMS supp form and get that emailed....can you or Brent just send me their email address please....
so all i now need to do is fill the supp form and get that emailed???
  • Replies 381
Posted Images
I could not answer that one for you at this stage given that that infor comes in when people send the supp regs back. Also that is in the domain of the comp sec rather than me (I am the editor of the CSA magazine but I get co-opted for anything required to get the Nats over the line)
NEED TO KNOW:
Anyone who is coming to the presentation dinner who has any specific dietary requirements? need to know asap!!!!!!
otherwise you will just have to make do.
Cheers
OK, all sprint entrants should get a phone call from the comp sec asking for this but if any have not had it could they please go here http://www.skylinenationals.com/Entry_and_...ls_12_09_10.pdf and download the sprint supp regs, fill in the formal sprint entry form and send it back ASAP. If you want to scan and email it (It might be best) send me a PM and I will send you and email address to send it to.
This is only required for people entering the sprint part of the nationals.
Edited by Blue
lol
Matty is very :P
we will be having a Drift Display but that is all
orly? whats that involve? im probably coming out for the sprint to do some TA, pending whether there are any spots left on the day.
they have signing on friday. then show and shine in glenelg on saturday and then sprint event at mallala on sunday mate....
also i will need to be signed in on sunday as i wont be back into adelaide on friday :)
krishy, i'll talk to the committee on thursday night and see if i can sign u in on friday (and bring the stuff to mallala sunday with me)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
