this does it.... why is every one in the forum getting defected one by one, about 3 months ago this topic was non-existence, is there some new ops running we dont know about?
The same could be said about break-ins as well...
Nice one inasnt, are you in your new house yet? may see you around :(
Yep moved in on the weekend, but i have been driving around a blue mazda 323 not my car coz its still NOT ready.
Gordo.
I am thinking about enlarging that pic and getting a few printed as stickers. Anyone interested in purchasing one off me? $2 each.
Gordo.
Ill buy a sticker
funky: there was actually some thing where somebody crossed out "victoria - on the move" or something back in the days of jeff, and he got fined or something and there was an outcry over it.. it was on a current affair so it must be true!
i think it is an offence to actually deface your numberplate..
Gordo.
sold, one for me thanks. Better set up a stall at chaddy or sumthin, you'll make a fortune out of it! :rofl:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
