They use Ohlin's double adjustable dampers, arguably the duck’s guts at the moment
Last, but by no means least, I can’t afford Mines prices, they make my nose bleed, they are so high
yeah, the mines damper was made by ohlin, but mines spec.
my friend quote a pair of dry carbon aero mirror of mines, ONLY cost a$1400, that is a price he buy in japan... :Bang:
  • Replies 74
guys,
what are your thoughts on maybe starting a "Project Thread" on specs to build our own "SAU Gtr N1", perhaps focusing on finer points rather than the average mods - Exhaust, Pods, PFC, CAI..
The criteria would be (maybe basing it on Mine's theory) eg:
1. Power limit around 600hp
2. Budget ??? (leave this up to you - maybe to save money we could option used) Maybe 10-20K
3. Weight reduction options - as light as possible
4. Has to be realisticlly street drivable
5. Like "the man who says he doesn't know everything ;)" SydneyKid said, "Mine's concentrate their efforts on response from the engine, not outright power" Maybe we should concentrate a little more here, also.
6. Finally, keeping the Sleeper look retainging as much of the standard car as possible.
^ Even the Gibson R32's had around 640 bhp and they ran on slicks
^ They run high compression ratios, over 9 to 1 is common
^ The Gibson R32's were 9.5 to 1
^ Before it can accelerate the car, the engine has to accelerate itself, so they use lightweight components like crank, rods, pistons, valves, retainers, buckets etc
But thats why im so supsicious of the Step 2 cars performance, the information i have is that its done all std bottom end!!! (based on the assumption that crank/rods/pistons increase an engines inertia more then the DOHC vavlegear)
What got me thinking about this was going thru my old vids which included GMS/Winfield GTRs and HKS GTR, the difference in which they revved in 3rd and 4th gears. (all cars are using 6spds)
That and so may credit the performance of the Mines GTR purely to the fact that it runs 2530s (as good as they may be, i dont think they deserve near the credit they recieve for the cars performance)
..and thanks Tony :(
  • 1 month later...
Wow...
Hardcore.
I think that people realise that POWER is easy.
Streetability, engine response is where it's at.
So in that regard what is needed to make the RB motors spin up fast to the redline.
I think carbon shafts are overkill but what about cheaper and more conventional items like lightened flywheels (I have a Toda!) and if you're really serious, lightened internals.
What else can we do to make the motor spin up with such ease?
T.
Well rotating mass is critical, hence a prop shaft weight reduction is so effective at allowing faster spin up. My ultimate goal is to make a "response R32" within a reasonable budget, hence I would like to hear if anyone has one of these props.
Tony: skies the limit... lighten everything :)
LW.
T.
They're not overkill if that's your only option.
Those Carbon prop shafts drop like 7-8 kgs from the rotational mass... How else are you going to do that? Can't shave that much weight off the crank, rods or pistons because you'll be affecting strength...
Pulleys? How much weight do they save? 500g? 1kg?
What else? Carbon Prop Shaft :P
If i don't buy this property i'm looking at, the 34 i'll be bringing in has always going to be a "response R34". Don't care about the drags at all. I think Troy aka ylwgtr might be the man to ask about a Carbon prop shaft.
My plan was to get a kick ass supsension setup, with some real good paws (light rims and tyres). Whiteline had quicker cars at the drag strip with considerably less engine mods on their cars bcos they had much better suspension setups. So make ur car go faster without making any intake/exhaust/engine mods. And then i guess once u got that down, try and trim some weight. But i suppose things like, FMIC, more boost, exhaust, CAI would be needed. And i guess a really good tune. Altho i really know nothing about internals, so in the search for response, i'm not sure what priority would be. I think i would head suspension first, with good rims and tyres.
anyways, would love to hear bout what other ppl think would be like the Top 5 things to do in search for response!
Hi Daniel, 5 things to do for response, not in any order;
1. Adj cam pulleys, tuned for response not max power
Or even better, (on RB25's) Tomei 256/260 Poncams (the "or" because their standard cam timing doesn't seem to need adjusting). For RB20's a set of RB26 cams is a good, cheaper alternative. For RB26's the standard cams are hard to beat.
2. Wastegate actuator with the spring rate as close to your boost max as possible and a boost controller (electronic or manual) that limits early wastegate opening
3. The right size turbo/turbos for your power target, bigger is not always better
4. Combination split dump and engine pipe, you need a combo because the replacement split dumps only, are too short and don't keep the wastegate exhaust away from the turbine for long enough (needs to be 400 mm minimum). In this case, longer is better. You need to follow it up with a good exhaust system.
5. Tuning, tuning, tuning it's the most important. I like to use lots of ignition timing, if you want to build some safety into the tune, then use a slightly richer A/F ratio. This costs a bit of HP but doesn't dull the response like retarding the ignition timing.
These are the things you should do, but almost as important are the things you shouldn't do;
A. Don't lower the compression ratio, it is the biggest killer of response, after ignition timing.
B. On a GTR don't touch the standard plenum, throttle bodies or inlet manifold. I have yet to see anything that improves the standard system's response. There is a strong argument for retaining the RB20/25 inlet as well.
C. The standard intercooler pipework diameter is good for most road/track cars. Be very careful about increasing the internal volume of the air flow system, this applies equally to the intercooler. Once again bigger is not always better.
D. The standard ignition system is perfectly OK for applications up to 650'ish bhp.
E. When you replace the clutch, as you will, don't go for the heaviest flywheel and pressure plate combo. You will find there are lighter combo that do the job just as well (if not better) and don't dull the response like a heavy combo does.
Enough from me, what do the others think?
SydneyKid
*1. For RB26's the standard cams are hard to beat.*
Why do people swear that cams are a must? I think I read a post of yours, saying the RB26 has 248~ cams. I was looking into a cams upgrade using stock internals with the GT2530's, but wondered which cams setting were best for my street application around 550-600hp. I noticed the Mines car has 2 types of set-ups, whats the difference and do I have to change anything else eg: valve springs... etc
IN 252°/lift 9.1mm
IN 260°/lift 10.2mm
EX 252°/lift 9.1mm
EX 252°/lift 9.5mm
*4. Combination split dump and engine pipe, you need a combo because the replacement split dumps only, are too short and don't keep the wastegate exhaust away from the turbine for long enough (needs to be 400 mm minimum). In this case, longer is better. You need to follow it up with a good exhaust system.
In other words dont bother with the HKS Dumps? I figured whilst they're fitting my GT2530's I could fit a set of HKS Split dumps at the same time. Cause the ones your talking about [Trust] are worth a fortune. But your not the first to say this, my tuner said the difference between the HKS dumps & stock dumps was virtually nothing. :confused:
Does anyone on here run a carbon prop? Anyone know where to source one? What about a Carbon Kevlar prop?
Like this
SAU Member "Harry" from the UK has one on his car, & pointed me to a great thread that's goes into detail about them. From what I remember, they cost around $2-2.5K, weigh about 8kg compared to 14kg, and did have drawbacks, something along the lines of reliability & could cause stress on other components. best to read the thread, or maybe someone else can correct me.
Like this
I have already read that thread. The concensus seems to be that its a great mod for response, with enough flex in the part to protect the gearbox, but with the possibility of higher wear on the rear diff.
Obviously anything with "Mines" on the side of it is going to cost a fortune, but I was hoping someone in Aus might have an actual price. Also, the Mine prop is only Carbon Fibre, so I wonder if there would be any advantages in making it from Carbon Kevlar...? Finally, it would be nice if an Australian company could come up with a design (even if it was only a direct copy) .... prices would probably be cheaper then :P
Lucien.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
