MTQ Engine systems are the largest GT dealer in the country. Try them also
As for your problem, I would say very characteristic of valve stem seals in the cylinder head.
that was my mechanics first thought a few months bak, and since then i have completely rebuily the head - new valves,guides,stem seals everything :yes: so now it just leaves the turbo, unless theres ne other issues that we may be looking over?
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5398653
Pull it out, strip its housings and check the conditions of its wheels. Turbo is suitable for rebuild only if your wheels are in ok condition with out too much of shaft play. Unfortunately most BB turbos would require a new CHRA for overhaul.
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5399413
Yes the HKS GT3037 Pro S turbos use the same cartridge as Garretts GT3076R turbo .
The cartridge number is 700177-5007 so you can shop around for the best price on one of them .
Anyone who can remove the compressor jamb nut and the oil inlet ferrule (without bending anything) should be able to strip the cartridge and assess it for you . The advantage of a ball bearing center section is that aside from the turbine end piston ring type exhaust gas seal nothing actually rubs against the bearing housing so unless its had some mechanical failing or the wheels are damaged it may be reusable . It really depends on what the turbo shop has in the way of spare parts .
A .
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5399633
Like the guys said, depends where you take it. Since i live in Perth i got Grant from http://www.per4manz.com/ to rebuild my HKS GT2835 PRO S.
The rear bearing race had collapsed resulting in the wheels JUST touching the comp housing. He repacked the cartridge/ balanced at a fraction the cost of a new core. Still going strong.
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5400014
I've had nothing but good experiences with MTQ too...call them and speak to then before you talk to anyone else...even people here on the forum...
cheeers mate :rolleyes: would u happen to have an email address or contact on here that i can contact them on?
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5404416
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
