MTQ Engine systems are the largest GT dealer in the country. Try them also
As for your problem, I would say very characteristic of valve stem seals in the cylinder head.
that was my mechanics first thought a few months bak, and since then i have completely rebuily the head - new valves,guides,stem seals everything :yes: so now it just leaves the turbo, unless theres ne other issues that we may be looking over?
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5398653
Pull it out, strip its housings and check the conditions of its wheels. Turbo is suitable for rebuild only if your wheels are in ok condition with out too much of shaft play. Unfortunately most BB turbos would require a new CHRA for overhaul.
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5399413
Yes the HKS GT3037 Pro S turbos use the same cartridge as Garretts GT3076R turbo .
The cartridge number is 700177-5007 so you can shop around for the best price on one of them .
Anyone who can remove the compressor jamb nut and the oil inlet ferrule (without bending anything) should be able to strip the cartridge and assess it for you . The advantage of a ball bearing center section is that aside from the turbine end piston ring type exhaust gas seal nothing actually rubs against the bearing housing so unless its had some mechanical failing or the wheels are damaged it may be reusable . It really depends on what the turbo shop has in the way of spare parts .
A .
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5399633
Like the guys said, depends where you take it. Since i live in Perth i got Grant from http://www.per4manz.com/ to rebuild my HKS GT2835 PRO S.
The rear bearing race had collapsed resulting in the wheels JUST touching the comp housing. He repacked the cartridge/ balanced at a fraction the cost of a new core. Still going strong.
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5400014
I've had nothing but good experiences with MTQ too...call them and speak to then before you talk to anyone else...even people here on the forum...
cheeers mate :rolleyes: would u happen to have an email address or contact on here that i can contact them on?
https://www.sau.com.au/forums/topic/332880-hks-3037/#findComment-5404416
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
