Might have to grab this on steam on a specials weekend or something.
Best zombies I got was lvl 31 with 3 mates... God I loved teh zombs!!!
Tell me your secrets!! How on earth did you get to lvl 31? What strategy did you use?
It's very irritating that you can't pick out what it is hey?! Hahaha
I'm fairly hooked on the zombies mode though. Wave 13 is my new best!
I swear people are using some sort of cheats to get to high waves, I just don't get what they are doing?
In a team of 4, you open up downstairs and have two people guard the windows whilst the other two guard the door. This is now your safe room (think of it as the upstairs section in WaW Der Riese; if you played it, that is). You instead take the upstairs path to turn on power. This way you take on the waves of zombies downstairs and use the areas upstairs to access guns and perks.
more players would have to be an advantage
More players is definately better although it does spawn a shitload more zombies. Microphones is the biggest advantage. I usually only play when other players have a mic.
do you know if its possible to play with 3 or 4 players locally in split screen? never tried this myself as i only have 2 controls
Can you just quickly ellaborate on this as I don't quite understand?
EDIT: Actually I think I get what you mean, I might give that a go :D
Edited by PM-R33
Only 2 player splitscreen campaign/zombies can be played... though there have been apparent glitches where a 4 player splitscreen zombies worked, this was with the classic maps that are only available with the hardened and prestige editions.
Friend of mine who plays online/PC - reckons its shit at this stage (game control mechanics are shit, but that'll be due to console IMO).
He plays all the FPS shooters - tier1, MW2, BC2 etc etc - so good enough of a review for me not to waste my money this time round.
black Ops is awesome! your friend is a nub.
having as much fun on black ops as playing Inf-only mode when it came out on BF2.
much better than MOH, MW2, BC2. smooth game play
vs bots is a good addition too.
+1 for your friend being a nub, but the multiplay is fraught with lag spiking, that and wanting to refresh the server list every time you quit or rejoin a game is annoying, apart from that it's good
lag spikes alone would make me not play an fps.
It's the stats server updating too often that does it.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
