You all aren't going to believe this
The dealer may not follow through with the deal even though we have paid in full, he now wants more money (after the sale)
see more http://www.skylinesaustralia.com/forums/R3...78#entry5401378
Fine, there are plenty of other track cars around. He just needs to pay for your time, and expenses paid. He'll never successfully sell anything again here.
Similar thing happened to my car, ended up not getting two tyres the guy had agreed to to. And more recently I agreed to pay for an air deflector which they guy then pulled as someone else later offered apparently more. At least I had not paid for it!
  • Replies 52
Posted Images
We are in possession, but I never want to have to go through anything like that ever again.
Thank you all for your words of support. Thank goodness so many know me so well and know the way i operate.
care to share the final outcome?
I love car dealers. the lies they will tell you to your face is amazing. when searching for a car it always worth a laugh to go look in the yards but buy else where haha
one place here in phillip tried to tell me that their black 35 gtr they had on the lot for 160k was a specv. when i said if it is consider it sold as i will be able to on sell it for at least 100k profit he walked away lol
More information will be coming once things get underway. The dealer in question took money from another dealer after I paid for the car in full. The other (innocent victim) dealer had a truck go to pick up our car yesterday morning, but I had already taken possession after having a further $2500 extorted from us to take delivery of a car we had already paid for in full.
I won't say more HERE until legals are completed, but it's not over yet. Myself and the other parties are taking legal and media action until I get my $2500 back. My barrister believes strongly that no judge would rule in the dealers favour after seeing my receipt and contract, and is so confident he will work pro-bono and recover his costs.
Feel free to pm me for updates
Something tells me that you'll need some rubber for it??
*hint hint* :D
Thanks Mick, thats good of you... I needed a sponsor and you need someone to push your tyres around the track :thumbsup:
I am the current NSW Tin Top and Class Champion *hint hint* and Im doing IRACE which is televised on Fox Sport and SBS... just get your people to talk to my people LOL
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
