Well time for the skyline to go, No time or motivation or money to finish it
So instead of selling it whole Im stripping it.
Pick up Preferred for large parts. In Canberra.
Ill start with the big stuff,
R33 Rolling shell, comes with gearbox and motor if you want them - $3500 with bare RB25DET long motor (no manifolds, turbos etc etc) os Giken Twin Plate Comp Clutch (the 600hp rated one) about 1/2 worn, 5 Speed 25det box, has Nismo Clutch Pivot Ball, Walbro Intank pump, FMIC blah blah blah,
Tein Super Street Coilovers, Whitline 22mm Adjustable rear sway bar, Tomei Hicas Canceller, Ajdustable Upper Camber arms front and rear, the fronts have seen ZERO Use!
It has stuff all interior left in it, Wiring looms have been pulled out and are sitting on the garage floor.
Brakes are Standard Calipers with RDA Slotted rotors, and QFM K500 Pads are in atm.
There is a heap of other stuff too, but cant remember it all
This is bloody cheap for what it is! The Clutch and gearbox are worth more than what im asking for a nearly complete car.
Also Selling a Greddy Copy Plenum with standard thottle body - $250, not very old and in good nick, no leaks and fits fine.
740cc High-flow RB25 Injectors in factory rail and with factory fuel reg - $200
Microtech Lt-12s Plug and play ECU for R32-33 Gtst's and GTRs comes with 4-line handcontroller - $750
Greddy E-Manage Ultimate N-4 Harness only suits R32-33 Skylines - $100
Alloy Surge Tank with hose tail ends, about 1.5 or 2L from memory Un-used - $50.
There is heaps more that I cant think of at the moment.
And Questions Just ask, Pm Is best
Thanks
Andrew
https://www.sau.com.au/forums/topic/333278-stripping-r33-gtst-and-other-parts/
  • Replies 69
Yes I have, them...arnt that great though, missing a bracket on the passenger side one and quite yellow
Also have a Fixed back bucket seat, no idea on the brand, bought it from a vendor at Superlap, its red and looks a bit like a sparco sprint. - $100
Remembered some more stuff,
Z32 AFM, Works fine and the mesh is good - $150
Idle Control Valve Thingo, works fine - $20
Rb25 Ignitor, Works fine - $20
Standard Coil packs, Still work but average condition, Come with the mounting racks - $50
Standard R33 Gtst ECU - $50
All prices are plus post for those that need it.
The starter is fine, yeah im prepared to post it, but no idea what they are worth,
And Ive already got 2 others interested in the Hicas thingo, So ill let you know.
Coilovers sold, Front strut brace nearly sold,
Camber arms are 99% sold.
Brake rotors have seen a couple of track days and around 5,000ks of road use, but dont look very worn, bit rusty from sitting around for months though. - $100 plus, post...they are heavy so post would be quite a bit id imagine.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
