just trying to work out what injectors i have, car is an r32 gtr
i know they are 1000cc, and i think they are sard.
it has an aftermarket fuel rail.
i was looking at a new set, but is there a way of finding out what they are without pulling them out.
i have been looking at some new sets, wondering what is best when it comes to,
impendance - have seen mostly low
multiple hole spray?
recovery time m/s
and how do i know what will bolt sraight in?
i am new to working with fuel setups so any help and knowledge will be great help.
cheers
https://www.sau.com.au/forums/topic/333298-injectors/
what colour are they? U can look up manufacturers offering for the rb26 for comparison, also if u running PFC with controller for example, u could find out the latency set for injectors for cross reference perhaps, injectors also have numbers on them that should be visible while fitted so u can google them
https://www.sau.com.au/forums/topic/333298-injectors/#findComment-5403719
Sard injectors, well Denso to be exact usually black bodies, with a colored top.. here's what a Sard (Denso) 1000cc injector looks like: http://www.sardracing.com/images/products/Injector63518.JPG
Rochestor 1000cc injector looks like: http://www.tweakit.net/shop/images/rochester_11mm.gif
Those are both 11mm o-ring injectors.
If it's a japanese injector, it's most likely to be a Denso injector.
The aftermarket fuel rail is an unknown, until you know the brand or more details about it, you won't know what injectors you can fit in it (whether it's a 11mm o-ring type or 14mm o-ring type rail).
You need low impedance injectors with GTR ECUs, what ECU do you have?
https://www.sau.com.au/forums/topic/333298-injectors/#findComment-5404066
ecu is an EMS 8860, and the injectors are black.
guess i will have to pull the rail off, was going to pull the injectors and get them cleaned and flowed too.
so i just measure the size of the holes in the rail to find out if there 11mm or 14mm??
cheers
https://www.sau.com.au/forums/topic/333298-injectors/#findComment-5408200
if i buy new injectors does the car need to be dynoed once they are fitted???
If they are a different size, you need to put that size and latency settings into your ECU, then get it checked on the dyno. If they're just new replacements of what you already have, you dont need to do anything.
https://www.sau.com.au/forums/topic/333298-injectors/#findComment-5411974
Why are you changing them anyway, the existing 1000cc injectors should support alittle over 600kw on PULP (not sure on E85, 450kw maybe?).
If you are replacing them with different brand 1000cc injectors, the lag time will need to be adjusted in the ECU as every injector has different response times, bigger or smaller injectors you'll have to do this anyway and adjust the injector size correction, either way though it is a good idea to run the car on the dyno to confirm the AFRs are spot on especially if you are making that amount of power.
https://www.sau.com.au/forums/topic/333298-injectors/#findComment-5411978
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
