I've bought an Apexi AFC Neo off a forum member, and have the manuals from the Apexi website. I also ordered an Apexi ECU Harness from Nengun so I don't cut into the original ECU Harness.
My question is, has anyone on here installed one of these before? If you have, please let me know how it went, what to do etc.
Cheers,
Adam
if you bought the harness then its should plug straight up
you may need to set the afm type tho, should be easy enough to find the info tho
the neo may even just have a menu and you tell it what motor (not sure, just a guess)
i put an old school safc on my r32, it reads the afm voltage then adjusts it up or down a percentage - your best to do this on a dyno but you can probably pull a few % of fuel out up the rpm range
or grab a wideband and get it up the exhaust and tune it yourself
As Tom said, it should plug straight up!
In the settings menu, set the 'Type' as hotwire and engine as 6 cylinder.
Also make sure it is all set at 0 correction before you start your car :huh:
I think the harness he means is like an extension the harness itself get cut and not your ogigional car harness. If I were you and had a series 2 I would sell it save a few hundred more and get a nitune! Much better onption way more tunability.
The advantage of the harness is that you can do the soldering on a bench and then just plug it in. You will need the pinout chart from the DIY section (although there is probably a basic pinout with the instructions). You can play with it yourself but really it needs to be tuned on a dyno or you could damage your engine.
Really you would be better off with a Nistune chip and sell the SAFC to someone with a S1 or M35 (i.e. someone who can't use a nistune chip).
I'm more looking to use the SAFC to get better fuel economy, by leaning out the Air/Fuel ratio for daily driving. And thaat way I can increase it for the track. I did think of the Nistune, but I can't really justify it for what they cost. The AFC Neo I bought cost me $250, the harness was just under $200. I bought the harness as I learnt the hard way about splicing devices into my S13 ECU harness and messing it up.
You have spent $450. Nistune is about $500 including software but for the extra $50 you can set the afrs much more precisely, set timing across the range, get rid of the speed cut etc etc. In either case you need to get a proper tune, preferably on a dyno. I had a SAFC and SITC as well as a wide band meter and played with it myself but couldn't get the same results as a good tuner on a dyno. I got better results with a chipped ecu (sadly not a Nistune as I have a S1 stagea).
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
