(B1) MR_fanny, I think you need a new mechanic, the problem is worn sychros between the gears (common problem)
And a quick shift kit will make the problem worse as it makes the synchros work harder.
Can syncro's be repaired or only replaced?
I put the Redline Shockproof in my gearbox about 8-9mths ago and while it was really good to begin with the last month or 2 i've noticed that its back to what it was on the old oil (crunches often)
I'm not sure whether to put in fresh redline (or another brand) or get a gearbox mechanic to have a better look at the -real- problem.
Thoughts ?
Just shift slower and put more redline in :worship:
And when something finally goes boom in there, replace the synchros while the box is out.
Even better, shift without using the clutch and the synchros will never be required at all :cheers:
JimX, I didnt think i'd find it because i read it like 6 months ago, so I didnt even bother to google it! hahaha
But yeah, I would only use shockproof if the gearbox is already shagged. If its fine, then I would use something else like maybe their MT90/MTL range. Additionally I would recommend Castrol Syntrans for the box and/or Motul Gear300 for the diff/box.
I was thinking of using Castrol VMX80 in my box. It's meant to do a similar job to Redline, but I'm not sure if it comes with increased wear. I wouldn't say my gearbox is shagged. It crunches into 5th fairly often, but not always. The other gears are fine. So I think I wanna do this sooner rather than later.
JimX, VMX 80 should be fine as thats what Castrol recommend for our Nissan boxes. However I reckon its a bit thin being a 75W-80, but I think it should be ok. I would recommend spending a little extra and getting Castrol Syntrans 75W-85 since its synthetic and a bit thicker! Otherwise Motul Gear300 75W-90 or Redline MT90 would do the trick!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
