I went to Unley Nissan in adelaide and they were f**king useless. Had to tell the guy 3 times what kind of car my V36 was, he then eventually said "We won't even look at an import, but we'll do a 40k service for $700" i asked what that included and he simply replied "Filters mate"
I enquired about the V36 transmission firmware update and neither he, or his boss knew what "Firmware" meant.
Has anyone been able to get the transmission upgrade to stop the auto hesitating and down shifting hard?
So getting a new key done is simply having it ordered in, and having the ID and immob code copied?
I don't know who Andrew is :P But am very eager to find somewhere in Adelaide to have a key done (hopefully less than $400 lol) and hopefully the firmware update.
Andrew = #Nightcrawler
He's in the SAU SA club and drives a V35. He should know someone.
  • 2 months later...
Hey guys, new to this forum, just purchased a 2006 nissan skyline pv36 350gt type sp and i only got one key from the seller, now i've been to nissan glen waverley (VIC) and also today i went to ferntree gully nissan (Vic) and both places states that they cannot do the coding on a spare key that i have. Ferntree gully advised me that the immobiliser code keeps changing when they enter and exit the program and thus they dont have the system to get the spare key coded and told me to go to infiniti or to an car import dealer if they can do it. Any suggestions as to what i should do now??
In short you are out of luck.
Is that basically the program they use? because as stated earlier in the post 3 years back lol, they were able to get the codes for the V36 by ChrisB, im not too sure, but i'll try contacting infiniti in melbourne if they noe anything at all about the car...
Yep you need consult 3 and a willing dealer.
no one else can help really as they cannot get the immobiliser code.
Dam maybe i should have thought about this b4 i bought the car lol, never knew it was so hard to program a key, i did try to contact nissan japan but of course no luck there, glen waverley nissan did give me a print out of consult III program sheet of the encrypted PIN but i guess thats the one that keeps changing...
Unsure. I have never needed to program a smart key. Normal keys were not a problem IF I had the immobiliser code . Nissan stopped handing those out a few years back.
  • 6 months later...
  • 3 weeks later...
Another recommendation for FTG Nissan. I believe I was the first spare to be made through them (2011 sometime), and they were great. It's cost me a bit more (exploratory work, etc) but it was under insurance thanks to Jetstar losing my bags!
Don't forget to get your mechanical key cut as well! You can't just go to any Bunnings / basic style key cut place, you need a locksmith who can cut both sides of the key. Should cost around $20. I had mine done in Elizabeth St, Melbourne, near the corner of Queensbury somewhere. I'm sure there are loads of places though.
If you fail to do this and lose your other remote then you will not be able to access your car at all in the event of an electrical failure / flat battery!
I've posted this before, but will throw this info back out there.
I went to Main North Nissan in SA, and they couldn't code my new key. They kept using the 350Z program.
Turns out the V36 needs the Nissan Micra key code program to work. I got lucky as a staff member was in the middle of importing a V36 and followed it up out of his own interest and got mine sorted.
$300, fob, code, cut.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
