OK, sorry for the lack of updates, but work got in the way for the past few months, and seeing as it finances the project, I couldn't really say no.
BETTER SAFE THAN SORRY
Having seen a fair number of incidents at the track, and also being a requirement for the race category I plan to enter, I finally bit the bullet and went the full cage. Asking around the racers in WA, one name kept popping up for who does the best rollcages. Brad Stacy. Working for one of the top Race Workshops in WA, and also working from home, I got in touch with Brad, and explained my requirements. Brad was awesome to deal with, and having done dozens of cages before I felt confident leaving my car with him.
The cage took about 2weeks, which wasn't bad considering he was doing it in his spare time. I'm really happy with the end result, and would recommend Brad to anyone thinking of getting a cage done in WA :thumbsup:
http://www.bradstacyfabrication.com.au/
Enjoy the pics
PICTURES
X side bar
Roof X bars
Front view
Rear Cage
Cage Rear Strut
Cage Hoop Top
Cage Hoop Bottom
  • Replies 76
Great work Paul,
Good to see Brad sorted Cage out :thumbsup: .
Whats next dude,
new RB30 :rolleyes:
I'm leaving the engine as is for the time being, makes plenty of power. Likely conversion to E85 fuel though, which should improve response and up the power a bit.
was just wondering about this car just yesturday, how long until it gets back on the track???
Potentially it could go back to the track within about 2weeks, but in order to get everything ready to pass scrutineering it will take alot longer. At least I'm back working on the car again, so progress will be made :thumbsup:
  • 4 weeks later...
just getting my battery nerd on, what are you thinking of using?
you can get pretty powerful motorbike batteries, they already use them in race/drift applications anyway
I'm getting a Braille Battery, only weights 3kg :D
http://www.autocraft.au.com/braille/index.html
bit expensive, but that is pretty light, what one were you looking at? how many cca?
are you looking at the lithium ion technology?
depending on the cca you require i'd say a Deka Powersports ETX18L or ETX30L,
they are a AGM technolgy and should have plenty of power and they could even sit around for 6 months and still start the car.
Give Goodchild Enterprises a call and they should be able to give you a good price on one, even tell them Erik from Bitz sent you
  • 3 weeks later...
stock cams will do 450rwhp wouldnt ever use that much grunt really in a track car, plus you would try to retain vct at any cost possible as it is a very good thing to have while tuning.
very clean car mate did you have a dyno sheet from the engine set up on page 1?
i was also supprised at the weight of the doors as well i have mine off at the moments and there feels like enough metal to make a charade out of them.
how much weight do you think you saved by stripping the wiring harnes out of curiosity?
Edited by kungpow
paul have you disabled the VCT to run the big cams?
looking to do this to mine but cant find out much about it.
Hi Tristan, I've got the biggest VCT cams I could find, Apexi 270degs. I think the VCT is one of the best parts of the RB25s. To be honest you'll struggle to find big VCT cams, so you may be stuck with disabling it.
I do somewhere, I will try and get a copy posted up.
At least 10kgs, I have shopping bags full of it.
  • 4 months later...
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
