R32 GTR V-SpecII
Brisbane, QLD
Genuine R32 GTR V-Spec II, with Genuine Factory Fitted Nismo Body kit. Great car, first Australian owner. Very Loved. Serviced every 5000km and gearbox/diff every 20,000km. Always garaged and regular weekly maintenance. Never been used on a Track or Strip. Was used as my daily driver for over 3 years, But a Work Accident means I can no longer drive it. The car has a few Minor Mods all have been carried out by Godzilla Motorsport. It currently makes 310AWHP and comes with a copy of the dyno sheet.
$30,000
Please Contact
Ben - 0420 909 676
post-200211-12822007051152205642_thumb.jpg post-200211-12822004801349268924_thumb.jpg post-200211-12822005371673738462_thumb.jpg post-200211-12822005831291152812_thumb.jpg post-200211-1282200615796238763_thumb.jpg
Edited by R32 V-specII
https://www.sau.com.au/forums/topic/333560-bnr32-gtr-v-spec-ii/
They did..
but, so I've been told they were weaker and some Jap owner removed them, and went to the orignals..
sorry to say but thats not correct they get taken and put on other cars or sold seperatly, brembo braked gtrs have taller discs and brembos are beater calipers which is way all of the rest of the gtrs had them(they are the exact same brakes as the 33 gtr) ,good luck with sale i,m not prepaired to pay $30,000 for an incomplete v-specII though i am looking for one cheers anyway
Thats just what i was told by the importer when i bought it... so i dare say it was them that took the brakes, if they are as good as you say.
Does anyone know if there is a Letter or Number in the vin that i can look for to confirm that it is a V-Spec II. Have had a fast check done on it and it has come back positive.
When i had the fast check done it also came back that the Nismo kit was a factory option on my car.
Model code should finish with AA, also check for the poprivets that hold the build plate on make sure try are still the tamper proof ones, there are plenty easier ways to get Brembos than to change discs, calipers, and probably master cylinders on a car that relies on those brakes to set it apart from every other GTR....
I checked those thinks today while cleaning it, the Model code does end in AA and it seams to have what i would call tamper proof rivets.
Is there anything else to prove its genuine?
i have to sell this car... its upsetting having a beautiful car like this just sitting in the garage, and being unable to drive it...
Now i've had 3 SCAMS off car sales..
So for SAU members i'll be dropping the price to $28,000, to help with a quicker sale.
Anyone interested please PM me and i can supply a full list of mods and any other car details.
Some of the bigger mods include:
Twin GT2860rs
700cc injectors
Coilovers all round.
and my fav, custom 3" stainless exhaust with Internal Mufflers and a Xforce Connon Muffler on the rear.
is it me or does the vspec sticker look way to high up..
we've already been through this... i've done all the checks and it is genuine..
i did have the boot resprayed a while ago tho, so the probable didn't put them back correctly..
Come on guys...
I need this car SOLD.
If your interested make an offer, i'm pretty open at the moment..
Please PM or call me i'll answer any questions you may have.
thanks.
As i keep getting told that it isn't a "Complete" V-spec II, through private emails.
I have now dropped the price to:
$26,000
To allow for the purchase of the Brembo's.. and to relocate the Sticker :P..
I have had over 20K spent on this car in mods, and can't afford to go much cheaper.
If you interested, please get in contact with me.
Not trying to hijack but differences are:
Wheels (also wider and larger rolling diameter)
Brakes
Rear Diff (ALSD)
Retuned ATTESSA
10mm lower suspension standard
Stickers
Rarity....
Given that there seems to be a shedload of V-Spec IIs floating around, I am pretty sure they have multiplied (and I have no reason to think or suggest mine is any more or less genuine than this car) however the 2 things that are the best indication (Model Code and VIN) say this is a V-specII, and they are harder to change than the brakes. I know that mine is missing the ALSD, again heard rumors of unreliability... To me this car is Genuine until a 1 owner car with complete history shows up with the same VIN.
Good luck with the sale, hope it goes to someone who appreciates it for what it is.
Thanks for the assistance. All the numbers do say that it is a V-Spec II.
Hopefully it can go to a good home, and to someone who knows what it means and not someone that has no idea.
Thanks
Ben
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
