Had an accident tonight.
Basically, the car in front of me hit the brakes hard and i swerved around him, clipped his bumper and then i hit the vehicle in the other lane.
All is good though, and i've got comprehensive insurance, just wondering if the damage looks repairable? I'm hoping it can be repaired but i've got an aero front bar and i know they're not that common.
What do you reckon boys? Repairable or write off?
Front what I can see, the damage is:
Passenger head light
Both fenders
Bonnet is a bit bent
Front bar cracked and has a hole in it.
Edited by dimi108
https://www.sau.com.au/forums/topic/333731-repairable-or-write-off/
Dimi, sorry to hear this..
It certainly look repairable as it mostly looks like panel damage and the headlight but those headlights are damn expensive.
Hope you are back on the road soon.
Cheers
Andy
Nissan can order the Aero bar in no problem.
Part number is K6020-AQ003 and it will come in unpainted.
First glance it looks fine.
However....
You'd need to look under/pull off the left guard to see if the sub-frame and if it's bent badly before drawing any conclusions.
+1
That's what I was thinking.
The price of the Aero front bar and one headlight.
Does anybody have an idea on how much an Aero front bar would cost brand new from Nissan?
Edited by dimi108
Guessing at least $2K+ for a bumper
I have thinking this myself... i dont think ppl would realise the damage bill they could cause if they have a minor accident with these cars, especially if there not insured.. Thats why im happy NRMA insured me with the window option, for instance they dont know what there in for if i break the rear window!!!
Im sure your bill will be less then a write off, however we just lost our 2004 maxima insured for $17K with similar damage except scratch went down one whole side of the car aswell.
But i cant complain coz it paid for my stag ;):)
Haha, sounds like it ended up good for you Matty.
The Stagea is only insured for $12,000, so if it's a write off, i'll just add a few thousand on top of the payout and get another M35.
I'll just have to wait and see what the assesor says tomorrow.
:D
Oops, don't bother quoting that number - it is specific to my chassis and comes in the BX9 colour.
Best bet would be to give them your VIN so they can put it directly into FAST...
I couldn't get a price from them as it is a factory option item... in Japan, thus Japan have to price it up I am told.
For reference,an unpainted standard bumper for RS is $770 inc GST so I wouldn't think anymore than around the $1k mark for a new Aero bumper (unpainted)
Thanks fellas. I really appreciate the input, links and information.
The car has been taken to the assessment center and I should know weather it's a write off or repairable tomorrow :rofl:
I enquired about that bar a while ago, they were after $180 from memory.
Spoke to my panel beater about getting it repaired, he wasn't keen given the prominent area of the repair (front & centre), very hard to get flat & smooth, and very obvious if it's not. Makes more work for the panel beater, can end up costing much the same as a brand new part in prep to get the right result, and even then, it may not be perfect. But it's up to you.
I would be expecting to pay around the $1000 mark for the aero front bar, otherwise start looking second hand on Import Monster or try Jesse Streeter, he reckoned he could get most parts, when I contacted him.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
