The seller tells me he has had this car for 3 months and is not SAU'r
but i am guessing there pretty good chance the previous owner is a NSW SAU'r, hopefully someone knows the Car a bit
can anyone help me please
here is the Car Sales ad
Any comments Good or Bad (Bad - PM me) is appreciated
In NSW
1. REV check - Free from Web site, so that not an issue
2. any Workshops i can get Compression Test / Leak down test done for a good price
3. i got Nissan Fast installed on my Laptop, so will check, but it is run of the mill stanard GTR not V-spec / II or NUR , so not much check there
Cheers
Kushil
in 2 minds about importing at the moment, has this one and V-spec lined up in VIC, but like this one more as i like silver
Is it just me or that price is very low for an R34 GTR O_O
Other people can help you with this Kushil, good luck for the future. (I would've helped, but I myself have no experience with this type of stuff lol, so I might aswell learn from other members ;))
Edited by Joy 17
I smells a bit like too good to be true, Some of the mods sound a bit silly....EVC boost gauge??? errr?? apexi PFC for 2k??? try $1000...the huge brembo brakes are just standard etc.
Might be worth having a look at though...Id be paying very close attention to the engine/turbo health.
This is just one I am keen on, so will have look at it and see
With an open mind.
But yes compression test by a good performance
Workshop inspection will be done, if I do
End up getting serious with it
Looks exactly like one that used to be from my suburb. The owner moved about 7 months ago to somewhere near Bondi and was selling it at the time he moved.
It was serviced well from what he told me, had N1 turbos, makes about 300rwkw. Tuned by Indy at I.S.
If its the same one, its seen some track time. Dont believe the k's.
N1 Turbo's aye...
Thanks
Can you guys spell out some names of workshops "preferable club affiliated" where i can pay over the phone to get inspection done of the car
I don't know any workshops in Sydney and don't really want RTA inspection normally these places are hopeless with imports, let alone modified ones
Never believed KM on a car, but if the motor is good and N1 holding Up well as they should...
might not be as bad as i thought
Georges Hall isn't really that far from Unigroup Engineering at 17/17A Amax Ave Girraween.
I'd have it checked over by Yavuz at Unigroup. It's worth the odd $125 investment. Ph: 9631 2470 E: [email protected]
Don't forget the little things.. It most likely will need a decent service at some stage.. Coil Packs, Spark Plugs, Cambelt, Fanbelts, Clutch, Tyres ect.
Just be prepared to give it a full service if not now it'll need one down the track :thumbsup:
Edited by Pandoraa
Thanks for Help Guys.. really appreciate it
but it look like he does NOT like to get it inspected
so time to move on to another one, unless that changes from the Buyer
No way in Hell i am buy a GTR without proper check up
Man if the guy is from Georges Hall and on his add says its not on revs and never been in an accident 100% something is up!!!! lol
I wouldnt waste my time, u know what they say you pay for what u get!!!
I cant see any genuine seller having a problem with a prospective buyer wanting to inspect the car unless they clearly have something to hide.
There are nice examples around for some good prices..just be patient & you will find what your after.
From the description, he's either really stupid, or knows his gtr and mods but just pretending to sound dumb. There's so much misinformation in there that even my 5 yo son knows those Volks are not 3 piece rims. However the RRP of 19" TE37's are more than that, so he's actually underquoted himself.
Now that I think about it, he is genuinely stupid.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
