And WTF are they doing. 39.9% is not full, so it is rather irresponsible to lighten restrictions going into spring/summer...
The north south pipeline was switch on this year, so that's probably part of the decision
Edit: Ahhh yeah... what Greg said ^^^
The only thing stopping me from washing my car now is time :D Too freaken busy :O
You have listed a Supra / 300ZX / MR2, which are the cars you "did" have, you would be busy washing 3 cars on your own.
Yeah, I need to change that :D Just refer to my sig for my car list.
You can now wash your car at home using a bucket or a high pressure cleaning device
- You cannot use a hose to wash your car
- You can of course use rainwater as you could under all stages of restrictions
This change has been made possible through a combination of factors:
- Melburnians commitment to water conservation the community has saved an additional 34 billion litres since the start of the voluntary Target 155 campaign. Melburnians have used just under 150 litres per person since the target 155 campaign commenced, a tremendous result.
- New sources of water are now on line and these add a new level of security and include the Tarago Reservoir and the North South Pipeline
- We have had much better rains. We had enough rain in Autumn to thoroughly wet the catchments and with the good winter rains storages are rising at over 1% per week. Currently our water storages are ~12% higher than the same time last year which equates to about six months consumption.
- Work on the new Desalination Plant at Wonthaggi is progressing very well, with completion still on track for late 2011. The desal plan will add another 150 Billion litres per annum which is about 42% of current annual water usage
I think if i hooked up my high preasure hose people walking the street would give me dirty looks just like when i washed my dirt bikes with it.. there like WTF ARE YOU DOING?!?! SAVE THE WHALES
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
