hey man just had search but i couldnt reli find what exactly i was looking for...i just need a quick answer...is it a big job to put a rb30de bottom end onto a rb25de? n will help me run higher boost more safely?
plz plz plz
The correct CR will help you run higher boost safely. so while u got the RB30 block apart, replace the pistons for lower CR, just grab a set of VLT pistons, they will be fine. if you read thru the rb30 conversions in the "forced induction performance" section, you will notice it isnt sucha big job.
if anyone is planning to do this, i have the stock R33 intercooler and piping for sale atm, for $80 ono. just pm me, its all in very good condition btw.
Don't be fooled gents. its not only the compression factor, but the piston itself, the N/a pistons are not Hyperputectic. therefore, even with low boost pressures, after a while you will melt a piston.
By all means, do this upgrade! turbo is 100% better effecient power, than most other mods. But do plan to change your pistons over in the near future.
Not really, my car ran fine for a over 50,000kms and as far as I know is still running fine without ever being cracked open to change pistons.
Melting pistons is from a poor tune, you can do it with any engine
the cast pistons will not tolerate the higher combustion temperatures associated with boost.
of course a good tune will help keep detonation to a minimum and the correct supporting modifications will ensure oil temps and water temps are kept low, but eventually the pistons will give up the ghost.
an example is my good friend who has a famous AE86 drift car here on the gold coast.
He had a stock 4AGE bluetop (bigport) bottom end which has the smallest rods, crank and gudgeon pins of all the 4AGE's and it took 6 months of punishment from a HKS GT2510 at 13 PSI pushing 150 kw at the wheels out of 1600cc.
It had a great tune from Adam from JEM and had all the supporting mods like a alloy radiator, great intercooler, big fuel system and oil cooler. The water temps never got above 82 and the oil never about 90 - 95. Eventually, the pistons gave up. But it goes to show that a motor can be pushed to nearly triple its factory power and still last for a while given that the correct supporting mods and great tune are applied.
Side note: I have read that the turbo RB30 pistons with the twin cam head will result in a 7:1 CR. too low
hey i just though i would go back a little bit and add something in, in relation to drilling the oil return line into the block a way of getting around this would be to buy an oil cooler and run the oil lines from the oil filter to the oil cooler to the turbo out the turbo then into the engine and around agian, this way you would have the best oil going to the turbo and you wouldnt have to worry about drilling holes in the block, and as a bonus it would be even easier to return to stock if needed
  • Like 1
13psi in a 10:1 is asking for trouble that would have contributed to the death of that engine...I owned a blue-top as well and managed to melt the piston without a turbo.
under 8psi with stock pistons will see a reliable engine that won't need forgies and will live a long prosperous life.
ive got vacuum hose running straight from the compressor nipple to the wastegate actuator and its natural boost is .8 bar.
i do have a bleed valve in the line but its completely shut. i might delete this as it may still be causing a boost increase.
If you've got an RB20 turbo that's normal though, the actuator I put on my highflow from an RB20 was 13psi straight on the actuator, no bleed valve.
Grab one from a series 1 R33, it should be nice and tired and give about 6psi
Absolute bullshit, my series 1 25de had the oil return just above the sump blanked off which simply unscrewed to fit my return line fitting. The same as the water return and oil feed, the only thing I had to source was a water feed which I t-pieced from a heater hose. Piss the rb20 crap off, accept a 25det stock turbo as a minimum.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
