The part number for a r33 cat in a N/A and a turbo are the same. I would only be using an educated guess but i reckon its the same for the R34.
If thats the case the dump pipe will match the cat along as it the original one from compliance.
Ok so I'll run an r33 dump and front pipe into my current cat and other pipes (for now).
More questions, with the intake we have the na with the big Y piece. The Gtt had the single straight cross pipe. Will I need to buy a new intake manifold from a Gtt? Or do I bolt the cross pipe to the big Y thing. I don't know what to call it! Haha
I've attached pictures.. Hopefully they work with tappatalk!
attachicon.gifImageUploadedByTapatalk1379183368.667917.jpgattachicon.gifImageUploadedByTapatalk1379183378.351019.jpg
You can get a custom 90 degree pipe made up or use a silicone pipe and attach to the end of the "Y" piece. Dan666 has/had this setup I think. You will have to remove the resonator box and get a GTt airbox :)
Still going along.
Things to do:
Mount intercooler to get piping made up ready for install.
Source intake manifold/cross pipe/bov/throttle body - alternatively I could weld up some pipe with a bov and attach that to the big Y throttle body. What ever is cheaper/easier.
Dump/front pipe still need them cheaply.
ECU! What will I do there?! is the AWD controlled by the main ECU? From what I can see there is a separate AWD computer. Hmm.
P.s some background on me:
I'm studying Science, im 23, I used to modify computers when I was in my teens. I also used to race karts and work on them. This is a bit of a learning exercise for me, but I have a few mechanics helping me out when I get stuck.
Get a Ebay front and dump pipe in one. They are about $299 and will get as good as the genuine ones if not better, not much more than 2nd hand genuine.
Also look at getting a braied oil feed line and braided coolant feed and return line kits. You get all 3 lines in the kit.
ahk, thought you were using a RB25 turbo.
The oil return should be on the turbo you have, it stands out (Its a15 cm metal pipe with about a 45 degree elbow bend at the bottom of it aimed towards the bottom of the block so it drains turbo oil into the sump).
There simple drain pipes, if you didnt get one with your turbo that one on Ebay looks to be a good alternative, you just bolt that plate to the turbo and screw one of the fittings in then the other into the block fitting and hook the hose up and its done.
  • 3 weeks later...
I've got Turbo Yoda from Mighty Car Mods giving me some advise on this one. He's actually told me that because of the NA motor I can run a bigger turbo than you would be able to in the Turbo model.
For now I'll run the RB25DET stock turbo.
Higher compression spools the turbo very quickly. On my auto I would reach full boost by at least 2,000rpm.
I lost compression after 40,000 kms of N/A+t, and I didn't drive it gently either. I was going to do a stag n/a+t swap with a larger rear housing turbo, but decided on reliability of a det swap which on stock turbo and internals through a heavy duty auto box netted me 215rwkw with a e01 boost controller and emanage blue ecu running map and afm simultaneously, tuned by Paul Fisher at Pulse racing. I'd take the swap over bolt on conversion.
Still collecting parts here, getting a bit poor and uni exams atm!
If anyone has cheap:
Oil/water turbo lines
front pipe
SMIC with piping (can trade for a FMIC with no piping, but its big and will fit the skyline front grill just haha)
what are people doing for the oil drain on a s1 r33 25de engine?
i'm thinking weld barb onto sump as its cheaper and quicker then drilling and taping in a new drain where that blanked off one is on the block, and dont have to worry about lost metal filings
There is a drain pipe at the top of the head for oil (above the power steering pump). It travels down to the bottom of the block and had a small 90 degree rubber hose at the end of the pipe draining into the bottom of the block. You can cut that and put a T piece in there and direct the oil drain from the turbo into that T piece.
Got my braided oil lines.
Rough pricing of things:
exhaust manifold + Turbo $100
Walbro fuel pump $50
R34 GTT manual ECU $100
Turbosmart type 2 bov $20 lol
braided oil lines: $70
dump pipe $20
Fmic $50
Just need a front pipe and then going to do intercooler piping
cheers
i'm a 20 man, only recently acquired a 25 and thought that pipe was for coolant :laugh:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
