Hey guys,
I'm about to start looking into making a single turbo low mount manifold for my 1jz, not really sure if I will actually use it on the car or not, but i wanna do it for a little project.
So I have a few questions
I dont want to use a merge collector due to space constraints, and I want it to look standardish, so thinking a log style manifold would meet the criteria.
So how do I get the runners to connect to the turbo flange (traditional Single entry T3) Im thinking 2 90deg bends and cut and weld them together and then squish them into the squareish T3 entry shape.
Any hints/tips/pointers/flaws in my plan?
Cheers
Andrew
Edit - here is a Tomei manifold for a late model VVTi 1jz and is kinda what im after but maybe not as fancy and in mild steel
https://www.sau.com.au/forums/topic/334094-making-traditional-turbo-manifolds/
As tidy as the manifold in that picture looks. I can only imagine the flow inside would be shocking. Gases running into more gases.
I wouldnt have used the tee's for the outlets. Rather 90's being merged into the back corner of the next one along. But for a simple easy to fabricate manifold that looks like the way to go! You could pump that out in one afternoon/night.
So all you need is 4 x buttweld fitting tee's and two buttweld fitting 90's probs long radius, and what looks like a piece of RHS to suit the internal dimensions of the T3 flange and then maybe another 90 for external wastegate outlet if you go that route. Id imagine all the buttweld fittings would be 1 1/4".
That log style manifold would be pretty damn cheap too. Maybe $100 to $130 worth of material...
  • 1 month later...
I forgot about this thread,
only looking for aboot 260rwks outta the 1jz
Also now looking at using a td06 so circular flange.
That is if I cant find a suitable manifold cheap off the shelf.
But I do like the idea of not having a stupid high mount manifold, stealth ftw lol
have you got the turbo and all that already? i've got a mate who's half half on selling his turbo kit atm, its on a jzz30. td06 25g with small as shit rear housing, with gate, manifold, dump pipe lines etc. made 275rwkw @19psi.
yeah we were playing with it on the dyno the other day, trying to get lpg tune and shit sorted. i think hes keeping his setup now though, trent helped him decide to stick with it lol. i'll still ask anyway for you. had another guy lined up to buy it but pulled out at the last minute to hiflow his standards, he was paying 2750 for it, so thats where the price would be at
i'll let you know if he changes his mind and wants to sell it
Sorry to hijack the thread.
If a great tune is performed on a N/A Skyline so torque and power are improved 10%, will the SVI LPG ECU ( hope the terminology is correct) adapt itself to the improved petrol performance. My Current LPG set up returns poor fuel economy so it will need to be fine tuned by the LPG technician. How then would a future great petrol tune affect a prior newly fine tuned LPG setup?
i take it english is not your first language?
i think what your asking is if you get it tuned on petrol, will the gas tune improve in the same way the petrol does? most likely yes, but on an NA skyline, you probably wont see massive gains anywhere, fuel economy may pics up somewhat though. how bad is the fuel economoy? within 30% of petrol?
English is my first language ......I am just retarded. :thumbsup:
LPG economy is 47% worse on a regular trip I do under the same driving conditions
haha sorry zebra :D
samuri, your english is alright, may have been pissed/tired/both when i read your post, makes sense reading it now :(
not up with the various types of LPG injection systems, but most dont have much of an 'ECU' as such, they are basically a complicated switch, with a mechanical restrictor of some sort to choke down the injector till it flows the same as your petrol injectors. sounds like the lpg tech may have left it a little rich.... if you tune the petrol though, it should improve the gas tune *assuming your system works the same way as most others*
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
