Hey Guys,
Just had the suspenioned overhauled in the r34 and looking for some sticky tyres! Car is making close to 500hp and from what i can see these are my options. any comments would be good!
Advan AD08
Nitto NT05
kumho ecsta ku36
ive also looked into semi slicks/drag radials but dont know much about what makes a good street semi slick/drag radial. Any advice would be great!
Cars one and only purpose is to go fast in a straight line.
https://www.sau.com.au/forums/topic/334462-best-dry-traction-tyres/
looks like that is the best choice there jez, but im running 19s and it looks like the ET street II only goes up to a 18"
i know ive handicapped myself a bit with a 19" but any chance you know any 19" drag radials?
Edited by Jap_Muscle
Any drag radial will have a higher profile than a street tyre, Its an inherent part of their design
A 19 inch drag tyre would look like a 4wd wheel. small rim and big rubber.
You would be better served by dropping to a 17 or even a 16 inch rim if drag radials are your choice. becuase of the tyre diameter they will still fill out your guards like a low profile street 19.
bang for buck the KU36's are awesome
NT05's are just amazing for street tyres (I run them on all 4's with 435rwhp) but expensive
but for drag, go a drag radial unless the car sees other use aswell
everything is a compromise mate,
only buy Mickey T's if you dont do any cornering stuff. Mickey thompsons are designed to have a super soft sidewall to obviously help hook up on launches. this is good for straight line stuff but it compromises vehicle stability and you start doing serious cornering stuff.
ku36's are shit at that power level, definately go the nittos. i just got a pair for the rear end of my r34 which will have around 600hp when finished and what the boss at tyrepower in hawthorn reckons will be the best for what i need.
ill be running the 36's on the front though as they are great for cornering and steering but not good enough to take power thru the rears.
my mate runs ku36's on his s14 with 200rwkw and i reckon they r at there limits with that. u get what u pay for .....
The KU's tread wear is more than RE001's 255's (read, they are softer, grippier)
So if RE001's are fine in my car with 270rwkw, barely breaks traction at all, then your friend needs larger tyres or some suspension/diff attention.
As is the problem with those types of examples, sometimes setups are fully correct and hence the tyres stand no chance regardless
although i do know this its starting to become outdated. what i mean by outdated is that most american muscle cars are running minimum 19" wheels and alot of companies are making 19" drag radials. Slowly but surely.
Nitto are the ones ones so far i know of though.
Joey i have been tossing up between the NT05 and the NT05R which is the drag radial version. being a drag radial i know a bit of what im getting myself into but im just worried the standard NT05s wont hold the power im making. do your NT05s break traction at all? what profile are you running?
Although i dont do any cornering (drift/track) it does get driven around on weekends and on the occasional cruise. technically it takes normal street corners and bends but i wouldnt be pushing anything. Do you see the MT ET Steets II causing me hassles in this situation?
i have been thinking about dropping down to a 18" for obvious reasons. but that wont happen till i sell my wheels. see sig for specs.
His point is though i think - 19's will never be as good as a 17's equivalent, regardless of if you can buy them or not :D
It's just pure logic really and the limitations.
What gives the advantage is the sidewall. On a 19, you have less than the 17, or 16.
The tyre has to be ever softer again to even come close to matching the grip levels (if at all) & last less longer again.
If you plan to run MT ET's or similar you'll be on a 17 (not 18s) at the most to be honest as Noel said.
Can't say I've ever seen a RWD car run a 10 sec pass with 19's on it :)
yea forget the 19's man, buy some 16inch wheels put some nice drag tyres on them, throw em in the boot and swap em at the track, if u just want a decent tyre for a 19, just buy street legal semi, KU36, 595RSR they cheap and good enough, my car drives like its on rails since i straped my RSR's on
compared to nittos they r....and i stand by what i said . speaking from experience here.
Experience of what? from what I can gather it's your experience of being told what to buy by people trying to sell you stuff.
buddy im building my bottom end to handle 1000hp + so i think that my choice in buying nitto parts over the cp is a good one.
however this thread is a bout tyres if u have a problem with something i have said then pm me
cheers
Pirelli Pzero Corsa semislick, get a quote from Taleb Tyres ($150ea atm for 18's, amazing price).
treadwear of only 60! awesome tyre thats for sure, grippy, very grippy
ku36 treadwear is 160 to compare against....
edit: stag is putting out 335hp @ wheels, Im guessing thats close to 400hp at the engine prior to drivetrain loss
i had the pirellis on my 19 inch vs kf on my r34 and they were grippy, just a flamin mongrel to drive with, really heavy in the front end steering feel. (due to the fact there 19's not the tyres)
cheers
Umm, you are paying someone else to build it you mean :blink:
Exactly haha
I do it for a living, and yeah someone sold him good and proper whether he likes it or not.
Anyway, why hasnt anyone mentioned RE55's in this thread? If dry traction is all the OP wants, they're great! Not a drag radial like the ET's, they're still expensive compared to KU36's etc but they're all sorts of grippy once warmed up. Life span is another story though
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
